something gone wrong with cam swap.
Old Nov 20, 2007 | 06:22 PM
GhostZ28's Avatar
so made a video of me trying to start it and it backfired horribly loud. I don't see how the timing could be off, I double checked before I bolted the timing cover on. I even double checked by pulling the fuel pump fuse, and turning the car over with the starter to check for ptv clearence to make sure I didn't drastically mess something up. but after I got it all together and really tried to start it, it sounded like something was shorted out, as I had a battery terminal short out once, and I know how it acts when that is the problem. I checked the positive on the battery and it burnt the hell out of my fingers. On top of that, it seems like I`m not getting any fuel or fuel pressure when I tested the little pressure test valve. I dunno what to do, I`m thinking it might have been setting up the lifter preload/ rocker arms. I`ve never done it before, but I followed the instructions for yellaterra rockers on ls1 howto. What do you guys suggest? Take it to a professional?
Old Nov 20, 2007 | 06:54 PM
Mike94ZLT1's Avatar
Did you do just a cam swap, or did you pull the heads too?
Old Nov 21, 2007 | 02:42 PM
Kraest's Avatar
Retired
Yuck.
There's no need to change out the stock rockers unless you're going to a shaft-mount setup.
Did you buy the right length pushrods? Did you adjust for 0 lash? Not having the lash set correctly can cause all kinds of backfiring and ****ty-running problems.
Mike
Old Nov 21, 2007 | 02:59 PM
2xLS1's Avatar
Find the cause of that first. Then check all your fuses under the hood.
Old Nov 21, 2007 | 07:11 PM
Mike94ZLT1's Avatar
I would bet that he has the starter wired wrong.
Old Nov 22, 2007 | 09:57 PM
DaddySS's Avatar
If the battery positive is getting hot it's a sign that you have high reisitance - maybe just need to clean and tighten the terminal. Start there, it should not get hot.
Klypto
Mar 23, 2016 09:05 AM
Amshnock
14
Jan 18, 2015 11:47 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Nostang 96z
Sep 14, 2002 08:22 PM
