Someone got a clue?
Old May 2, 2004 | 07:08 PM
Chenzz's Avatar
Question Someone got a clue?
Ok so Ive been having problems with my Z that Ive been trying to work out but everything seems to only help for a little while. First I was told a needed a new pump so I did it. Then I had a couple of shot coil packs so I did it. A couple other things here and there, so I did it. Finally im just fed up so I bring it to a performance shop and run it on the dyno with a fuel pressure gauge and apparantely my car is going completely lean the harder I hit the pedal.
The gauge we put on says its running a constant 24 psi which is less than half of what we should be running. We tried blocking off the regulator to see if that would cause a spike in pressure and be the problem, but that didnt cause a difference.
The shop owner thinks maybe there is a kink in a line somewhere, but im not too sure. Anyone have a clue I could use some help.
Thanks,
Vinny
Old May 2, 2004 | 07:26 PM
mullettour's Avatar
Have you changed the obvious fuel filter?
Old May 2, 2004 | 08:19 PM
1984camaroz28's Avatar
its not that hard to do a fuel pump if its not your filter
Old May 3, 2004 | 12:16 AM
Chenzz's Avatar
I aready changed the pump and the filter
Old May 3, 2004 | 11:41 AM
and it still has low Fuel presure?
Old May 3, 2004 | 10:31 PM
Chenzz's Avatar
Yup still got low pressure
Definitely mind boggling
Old May 4, 2004 | 01:50 AM
AL SS590 M6's Avatar
Moderator
Bad replacement pump or it's leaking where the pump hooks on?
Old May 5, 2004 | 09:15 PM
huttler's Avatar
Maybe the fuel pump relay?? I've also heard that if the oil pressure sensor can cut fuel pressure if the PCM doesn't detect oil pressure.
Old May 6, 2004 | 09:42 PM
Chenzz's Avatar
I was thinking about getting the fuel pump controller by aeromotive, will that replace the relay if thats the problem?
I also am going to get an adjustable regulator but the only one I found was the Kinsler on Thunder Racing for $400. I think thats a bit high. What is another good brand and where can I get it?
Boss002
Jul 24, 2015 10:47 AM
Flint78
Jun 21, 2015 01:28 PM
Zuvell
May 15, 2015 08:18 PM
zxtce
May 7, 2015 08:53 PM
bertius
3rd Gen / L98 Engine Tech
Sep 5, 2002 04:02 AM
