SLP LS6 Intake Manifold worth it?
yeah but most guys willing to do a manifold swap are more than willing to remove all that crap.it makes the engine bay look really cluttered (as if it weren't already). and as simple as it is to program out, and block off...why not.
and the Holley unit DOES have the hole for the egr. however if you plan to remove it you can just put a 1 3/8th inch block plug in the hole. works perfect
Originally posted by teke184
some people will say that the pipe that extends into the intake, directly in the intake flow path, robs some hp...
well i suppose it could...maybe 1/4 of hp....
the EGR system is that black hose/tube that starts right behind the throttle body on top of the intake, curves towards the passenger side, into a cylindrical valve thing, mounted on a bracket, and then a pipe goes down into a fitting that is attached to the manifold.
that's it....
you block off the fitting on the manifold and you plug the hole in the intake....remove everything in between and it's gone...then you need to program it off the computer or you will have an SES light constantly.
car with egr
car without egr
that's it....
car with egr
car without egr
something about the cam i think is how the later models passed emissions, not positive.
it is possible that you could pass the sniffer without the egr, however if they check the computer they'll notice you had it programed off or if it's not there (functioning).
that is basically why the aftermarket manifolds have the provisions...
CARiD
Jan 27, 2015 06:27 AM
Jul 4, 2005 05:00 PM
