SLP LS6 Intake Manifold worth it?
Old Apr 12, 2004 | 12:49 PM
  #16
teke184's Avatar
yeah but most guys willing to do a manifold swap are more than willing to remove all that crap.
it makes the engine bay look really cluttered (as if it weren't already). and as simple as it is to program out, and block off...why not.
and the Holley unit DOES have the hole for the egr. however if you plan to remove it you can just put a 1 3/8th inch block plug in the hole. works perfect
Old Apr 12, 2004 | 02:03 PM
  #17
AL SS590 M6's Avatar
Moderator
Originally posted by teke184
some people will say that the pipe that extends into the intake, directly in the intake flow path, robs some hp...
well i suppose it could...maybe 1/4 of hp....
Try this. Get out your shop vac and hook the hose on the output. Turn the vac on. Now stick your finger into the path of the air. Blows pretty hard on your finger doesn't it? What do you think that that might do to the air flow in the intake?
Old Apr 12, 2004 | 03:16 PM
  #18
Pasky's Avatar
I'd go get the LSX intake for that price.
Old Apr 12, 2004 | 07:03 PM
  #19
1stls1's Avatar
Does anybody have any pics of the egr system? I haven't really heard much about it. The LSX intake will work great w/ other air mods from what I here.
Old Apr 12, 2004 | 07:16 PM
  #20
teke184's Avatar
the EGR system is that black hose/tube that starts right behind the throttle body on top of the intake, curves towards the passenger side, into a cylindrical valve thing, mounted on a bracket, and then a pipe goes down into a fitting that is attached to the manifold.
that's it....
you block off the fitting on the manifold and you plug the hole in the intake....remove everything in between and it's gone...then you need to program it off the computer or you will have an SES light constantly.
car with egr
car without egr
Old Apr 12, 2004 | 08:55 PM
  #21
bluecmaro96's Avatar
what if you have emmisions in your state how do you pass with no egr? how do the 01+ pass? would mine or would they say its a 00 and should have egr?
Old Apr 13, 2004 | 04:42 AM
  #22
teke184's Avatar
something about the cam i think is how the later models passed emissions, not positive.
it is possible that you could pass the sniffer without the egr, however if they check the computer they'll notice you had it programed off or if it's not there (functioning).
that is basically why the aftermarket manifolds have the provisions...
Old Apr 13, 2004 | 05:27 AM
  #23
ULTIMTEORANGESS's Avatar
yes,GM eliminated EGRs in our cars by using more cam timing.
Old Apr 13, 2004 | 08:42 AM
  #24
LT-14me's Avatar
I would go with the holley LS6 "Style" manifold instead, i think its around $400 new? And it yields more hp. The LSX manifold is nice but for about $600+ they can keep it.
Noer
Feb 28, 2015 11:29 AM
alex5366
Feb 17, 2015 08:12 PM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
