SLP Cold Air Intake
Old Feb 3, 2012 | 07:48 PM
sdeluca1969's Avatar
SLP Cold Air Intake
Hi, i have a 2002 slp ss, I have the slp air box and blackwing installed from the factory. Anyway I have been looking at adding the slp maf and the slp smooth bellows and along with that I plan on putting on the slp cold air intake.
SLP Cold-Air Induction Package - 1998-02 V6/V8 Camaro/Firebird [SLP21033] - $129.95$120.46 : MarylandSpeed.com- Your First Stop on the Way to Performance!
Anyway my question is how exactly is that cold air intake installed?
Thanks for the help
Old Feb 4, 2012 | 05:26 AM
rod442's Avatar
Re: SLP Cold Air Intake
remove the airlid and filter. the aluminum part that looks like a duct, slides down parallel with the radiator (points at the ground). to draw cold air that hasn't been heated by forcing it through the radiator.
look at the supersucker ram air instead, or SSRA. IMO it works better since it draws air form much lower and away from the engine heat. BUT, you have to be carefull if you live where its very rainy, or around puddles. dont want water in the motor. (it comes with a block off plate for this reason).
http://ls1tech.com/forums/sponsor-sa...store-com.html
the above link isn't a vendor recommendation, just an example of what it looks like.
Old Feb 4, 2012 | 01:49 PM
Marc 85Z28's Avatar
The MAF and bellows are a waste of money. They will not make any additional power. Spend elsewhere.
30thZ4C
Dec 26, 2014 05:09 PM
thenewkid
Nov 27, 2014 09:41 AM
YellowTransAm350
Mar 2, 2003 03:38 PM
slothgrant
Aug 22, 2002 03:01 PM
BM93Z
Aug 22, 2002 02:45 PM
