SLP Air Lid questions on fit
Old Aug 6, 2013 | 07:38 PM
akwa's Avatar
I put an slp air lid on my car and it doesn't have a tight fit in the back and has minor gaps in the front two corners. is this normal and or will this affect my performance? Is there a way to check this out?
Old Aug 8, 2013 | 09:36 AM
02 6Spd's Avatar
Re: SLP Air Lid questions on fit
Mine also had a gap in the back. I fixed it by adding the foam strip that comes with the lid and also installed the full perimeter foam seal that came with my K&N filter. It's actually doubled up in the rear of the lid, but it sealed up the gap. If you take a flashlight and lean over the radiator you can see if the foam is touching the edge of the filter.
Old Aug 9, 2013 | 12:41 AM
akwa's Avatar
I put the strip that comes with it on but that's prolly the best way to do it. ill look for a full foam piece from an air filter, Thanks
Old Sep 1, 2013 | 05:24 PM
Mr99SS's Avatar
that's the slp lid fit issues I just had ... my mti fit tight
Old Sep 4, 2013 | 01:54 PM
bluz28's Avatar
Try a different brand air filter I know a lot of people have had fitment issues with the drop-in k&n air filter over the years, but I don't know if that's still the case (I quit using oiled air filters a long time ago).
Old Sep 4, 2013 | 04:46 PM
WhiteHawk's Avatar
My SLP fit fine. The big thing I found with the SLP's is that you need to work hard to get all the tabs inserted. And I also still us AC filters. Never liked those oiled ones.
-Geoff
Old Sep 4, 2013 | 07:42 PM
Mr99SS's Avatar
I bought the cold air intake kit. it came with a blue non oiled filter .... I had to heat up the end of the lid with a heat gun to fit the maf sensor.
Old Sep 4, 2013 | 10:35 PM
akwa's Avatar
I heated the end up and the maf was a bitch but I got it in and sealed good. what filter would everyone recommend to fit with that lid?
Old Sep 7, 2013 | 06:40 PM
Mr99SS's Avatar
yeah its real tight like a virgin!
95chwagon
Jan 13, 2015 09:19 PM
NED4SPD
Sep 16, 2002 10:45 PM
Geeterman
Aug 4, 2002 04:03 AM
ls1z01
Jul 30, 2002 02:39 PM
2000silverz28
Jul 20, 2002 06:14 AM
