View Poll Results: Remove or keep MAF screen?
Remove
23
71.88%
Keep
9
28.13%
Voters: 32. You may not vote on this poll
Should I remove MAF screen?
Old Dec 11, 2002 | 03:49 PM
therealmagyver's Avatar
How many of yall removed the MAF screen? And for those who haven't why not?
Old Dec 11, 2002 | 04:04 PM
ratio411's Avatar
If I was to port another MAF, I would keep the screen and hog out the MAF rather than doing both. I learned too late that the screen has a specific purpose. It straightens the air flow over the sensor so it can take an accurate reading. The MAF sits at a funny angle compared to the lid and TB, not to mention the fact that the lid is a compromise in airflow, so the air takes many tumbles as it travels. If it was me, I would hog the MAF, leave the screen.
Just my opinion.
Dave
Old Dec 11, 2002 | 04:07 PM
PhantomTA's Avatar
Moderator
remove it.. another myth
you sure dont see any z06's with screens do ya?
Old Dec 11, 2002 | 04:20 PM
ratio411's Avatar
You have a point, but I have been thinking about that... A Vette's intake system seems straight and more direct compared to ours.
May not mean anything. I sure would like to try this and see what happens though. It's just not a priority to me.
Dave
Old Dec 11, 2002 | 05:17 PM
redz_02's Avatar
i never heard it straitens the airflow, I always figured it was to keep large particles from your airfilter, say if it breaks, out of your intake. Kind of like a fail safe.
Old Dec 11, 2002 | 05:27 PM
ZZed's Avatar
The primary purpose of the MAF screen is to direct air perpendicular to the MAF sensor. If that doesn't happen, the MAf thinks less air is entering the combustion chamber resulting in a lean mixture. Worst case senario....detonation Some people don't have a problem, and others have the SES light staring at them. The F-body has a bent intake. The Z06 has a straight intake which mean it does not need a screen. Stopping large particles is a bonus. I'd leave it, but then, I'm not doing any mods soon.
Old Dec 11, 2002 | 05:57 PM
sabowabo's Avatar
I agree with ZZed, the MAF screens purpose is to straighten airlfow so the MAF gets an accurate count. Your asking for trouble if you remove it.
Old Dec 11, 2002 | 10:20 PM
Pentatonic's Avatar
Hmmm......did Dave D just get owned?
At any rate, I would just leave the screen in. Seems like the riskes outweigh the benefits.
Old Dec 12, 2002 | 12:06 AM
Drew778/94Z's Avatar
Just get a LS-6 MAF
I haven't had a problem and it's good for a 1.5 mph in the 1/4.
Old Dec 12, 2002 | 03:46 PM
JaysZ's Avatar
I removed mine. I figure my air flow is pretty 'straight'. If it's good enough for the Corvette, then it's good enough for me. I have not had any deleterious effects.
Old Dec 12, 2002 | 03:52 PM
NEWBIE T/A's Avatar
Lightbulb Another Leave it here !
MAF ends are cheap enough @ $ 100.00 or so that it would be easier IMHO to buy them & leave the OEM pieces intact.
That way, in case it does cause a lean condition, you could always put the factory front back on.
On a side note, when I dynoed my A/F showed rich at the higher rpms, so I put the Thunder Racing ends I had in storage on to see if that helps any.
My .02
Britt
Old Dec 13, 2002 | 05:26 AM
JBF94SC's Avatar
Just leave it alone is my vote for the +/- 0.5 hp who cares do a real mod and get rewarded with true hp gains.
Just my 2 cents
Justin Falla
Old Dec 17, 2002 | 12:14 AM
code4's Avatar
i read an article about this, "son of sam" in carcraft.(very good article, shows many mods and gains on dyno & 1/4 times) if i am correct on this screen, they removed it and had some gains but claimed it was because of an advance in timing? they warned that if you remove this to not use any gas less than 92 octane b/c your engine will no longer be able to retard the timing when pinging is occuring. according to them this piece somehow controls this ability to retard the timing. they also added that once the computer retards the timing it will not reset until the gas tank level is manipulated. this is because they programmed it this way assuming that once you fill the tank you have replaced the lower octane fuel? the vehicle in this article was a 2000 ss that the "school of automotive machinists" is working on.
hope this helps.
Old Dec 17, 2002 | 10:41 AM
PhantomTA's Avatar
Moderator
I havnt had a screen since march of 98..
cmon now
Old Dec 20, 2002 | 10:13 PM
jimmyblue's Avatar
Cars that are programmed naturally rich respond well
to mods that cause lean mixture error (like porting
MAF or MAF ends). Cars that are lean get knock retard
instead. The '98-'99 I believe were richer, the later
years not so much. The power improvement is more
from mixture than airflow, airflow is the only "reason"
for descreening and porting the MAF. It's voodoo
mechanics. Buy a used MAF for $40 and go play,
mix-n-match, Dremel to your heart's content.
I swapped a descreened end onto my '02 and didn't
notice anything positive, just a bit more slip on the
shifts of the automatic. So I went back. Not worth
the wear / risk on automatics.
Much more bang from throttle body and throttle cable
cleanup, I tell you. Just as free, way more kick.
CLEAN
25
Aug 20, 2018 01:31 PM
slocody
Feb 10, 2003 01:04 PM
RedLineRev
Jan 23, 2003 03:51 PM
Teal94V-6
Aug 31, 2002 09:21 PM
sfGi8nt
Aug 1, 2002 05:54 AM
