Could Somebody Tell Me How To Remove The.......
Old May 31, 2005 | 02:57 PM
flounder564's Avatar
I Know Its A Bad Idea But I Am Dropping My 94 Z28 Off At The Shop In 2 Days So Since Its Just 2 Days How Do I Remove S.e.s. Light
Old May 31, 2005 | 03:23 PM
teke184's Avatar
Re: Could Somebody Tell Me How To Remove The.......
remove it as in take out the bulb?
or scan it and figure out why it's on...
not sure what you really mean...
Old May 31, 2005 | 03:26 PM
turbo_Z's Avatar
unhook your battery for 30 sec. and that will erase the code thats causing the SES light... of course unless you fix the problem the light will come back.
Old May 31, 2005 | 03:37 PM
I Just Want To Disable It Because My Car Drives Fine For About 20 Minutes Then The Light Comes On And It Starts Jerking And Stumbling All Over The Place And For Some Reason The A.c. Goes From Cool To Hot
Old May 31, 2005 | 03:40 PM
turbo_Z's Avatar
Ok but you must understand the cause and effect. The SES light is not the cause.. it is the effect. Disabling the SES will not fix anything because its simply the warning light telling you something has gone wrong and you must fix the problem before the light will go away.
Old May 31, 2005 | 03:44 PM
Thanx For Clearing That Up, Do U Have Any Idea Why It Makes My Air Start Blowing Hot. Just Curious
Old May 31, 2005 | 03:50 PM
turbo_Z's Avatar
Because your AC compressor shuts off. I dont know why that is happening but try running w/o the AC on and see if the problem goes away.
Im not going to start guessing what is wrong with your car because you could end up spending hundreds of $$$ and still not fix the problem... MANY people have falling in that trap! The best advice I can give is to go get the PCM scanned to see what error code is setting off the SES light.
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
