Rocker arm kit installation Question?
Old Jul 31, 2004 | 09:23 AM
JS99Z's Avatar
I am installing the comp cams 1.75 rocker arm kit on my 99 z28. I have a question about the 5/16 guide plates. Are the guide plates mounted underneath the factory rocker arm shaft? That looks like the only place they can go. I just want to be sure!
Thanks.
Old Jul 31, 2004 | 01:54 PM
SSpdDmon's Avatar
Re: Rocker arm kit installation Question?
Maybe this will help you some.
Cam Help - 1-800-999-0853
or
http://www.cranecams.com/pdf/438e.pdf
Old Jul 31, 2004 | 11:32 PM
mrr23's Avatar
they go under the rocker studs. remove rocker,remove pushrod, remove stud, insert guide plate, insert stud, insert pushrod, install rocker.
oldschool
Feb 9, 2016 09:21 PM
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
