Reseting Trip Odomiter
Old Feb 6, 2003 | 10:06 AM
Beefcake61's Avatar
Question Reseting Trip Odomiter
Last week I was able to get my car out in some-what decent weather. I turned the car on and let it warm up a bit and when I got in, I noticed that my trip odomiter was reset to zero. Now I didn't think much about it but after going to a friends house and coming back out after a couple hours, it reset itself again. What I need to know is if this is going to become a large problem, or is it just because it hadn't been run in probably 2 - 3 weeks. Any info is greatly appriciated
Old Feb 6, 2003 | 10:41 AM
NEWBIE T/A's Avatar
Lightbulb There is a TSB on that ...
Which I just e-mailed to ya.
Cold weather causes this on the 99's only - low battery voltage may add to the troubles.
The "fix" was to swap instrument clusters for a new style circuit board that eliminated that problem - easy enough, but the car's PCM has to be reprogrammed to accept the new cluster.
This is pretty much a dealer only type scenario ...
(Reprogramming the PCM.)
The downside to the fix is that the readings on thre gauges may change due to a different cluster being used - on the SS, that caused my oil pressure to read lower , and the temp gauge to read hotter, than with the previous (original) cluster.
Drove me bonkers !
I finally went straight to the local reman house (where the dealers get the clusters as per GM ! ) and got it swapped for free, even though the dealer did not want to help.
I then had to go to the dealer to have the PCM reprogrammed to accept the new cluster - I had to fight to get a refund of the 1 hour labor charge to do so.
I got it, though !!
My advice -
Leave it alone !!
It won't cause any trouble that I know of, and it will go away by itself as the temps warm up.
Best of luck either way !!
Britt
Old Feb 6, 2003 | 10:47 AM
Beefcake61's Avatar
Thanks for the information. It's nice to know its not a major problem. Now if I would decide to get this fixed, is this something I would have to pay for? I didn't buy the car new if that makes a difference. Thanks again
Rob
Old Feb 6, 2003 | 10:52 AM
NEWBIE T/A's Avatar
Unhappy It does not hurt to ask, but ...
My bet is that you would pay for the repair as it is out of it's 3 year warranty.
Like I said, it doesn't hurt to ask - take a printout of the TSB with you when you go - don't do it via phone.
I hate to say , but most Service Writers don't know $hit about the products they deal with.
Pretty sad ...
Britt
Old Feb 6, 2003 | 03:39 PM
steelerfan's Avatar
My 99 did the same thing,luckily it was still in warranty when it happened.Dealer replaced the cluster.
68camaroboltz
Oct 5, 2015 11:56 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
detroitmuscle
Jul 31, 2015 04:21 AM
surreybrad
Jul 29, 2015 02:55 PM
Campbellb48
Jul 5, 2015 06:31 PM
