replacing rear seal on 02 Z28. replacing clutch too. suggestions
Old 02-18-2013, 10:01 AM
wayne braddy's Avatar
I am having mechanic replace leaking rear seal. Also replacing clutc kit. Should I also replace master amd slave cylinder. 150000 miles. Ist time on site, sorry if in wrong place
wayne braddy
wayne braddy is offline
Old 02-25-2013, 08:30 AM
rv93's Avatar
Re: replacing rear seal on 02 Z28. replacing clutch too. suggestions
you really should replace the slave cylinder. its inside the bell housing, so it really takes a beating. the master tends to go out unless you regularly change your clutch fluid, so its up to you on that one.
rv93 is offline
Old 02-25-2013, 09:38 AM
vettedog72's Avatar
My rear seal needs replacement too. I have an automatic so no clutch work needed. Can you share what the cost to pull the tranny and replace the seal or is you estimate bundled? Thanks in advance for your response.
vettedog72 is offline
Old 03-02-2013, 04:35 PM
Seems "wayne" never came back to the site after he posted the above message.
Injuneer is offline
Old 03-20-2013, 11:38 AM
Ultra_Z's Avatar
cause he's stuck under his car still...
Ultra_Z is offline
HectorM52
07-30-2017 11:46 AM
Jazsun
12-29-2014 12:14 PM
mattszm6
12-14-2014 07:09 AM
siguy
11-27-2014 10:07 AM
Quick Reply: replacing rear seal on 02 Z28. replacing clutch too. suggestions
