replacing rear seal on 02 Z28. replacing clutch too. suggestions
Old Feb 18, 2013 | 10:01 AM
wayne braddy's Avatar
I am having mechanic replace leaking rear seal. Also replacing clutc kit. Should I also replace master amd slave cylinder. 150000 miles. Ist time on site, sorry if in wrong place
wayne braddy
Old Feb 25, 2013 | 08:30 AM
rv93's Avatar
Re: replacing rear seal on 02 Z28. replacing clutch too. suggestions
you really should replace the slave cylinder. its inside the bell housing, so it really takes a beating. the master tends to go out unless you regularly change your clutch fluid, so its up to you on that one.
Old Feb 25, 2013 | 09:38 AM
vettedog72's Avatar
My rear seal needs replacement too. I have an automatic so no clutch work needed. Can you share what the cost to pull the tranny and replace the seal or is you estimate bundled? Thanks in advance for your response.
Old Mar 2, 2013 | 04:35 PM
Seems "wayne" never came back to the site after he posted the above message.
Old Mar 20, 2013 | 11:38 AM
Ultra_Z's Avatar
cause he's stuck under his car still...
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
mattszm6
Dec 14, 2014 07:09 AM
siguy
Nov 27, 2014 10:07 AM
