Replacing fuel pump
Old Mar 28, 2004 | 03:23 PM
AggieTA's Avatar
Replacing fuel pump
Okay I just want to know what is the easiest way to replace my fuel pump 99 TA
Old Mar 28, 2004 | 04:38 PM
TheMT1's Avatar
It's pretty easy.
There's two guides here if ya need them.
http://www.installuniversity.com/ins..._documents.htm
Old Mar 29, 2004 | 12:31 AM
99snkklr's Avatar
Re: Replacing fuel pump
I don't think they're talking about fuel filter replacement. Go to www.ls1tech.com and do a search. There will be several posts about swapping fuel pumps on 99-02 f-bodies. The easiest way is to cut an access panel in the rear deck just behind the rear seat. Do the search and you will get all the info you'll need.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
