Replaced EVERYTHING on the front of the engine... still squeals...
Old Sep 19, 2003 | 08:52 PM
  #16
AL SS590 M6's Avatar
Moderator
2 things that you didn't mention.
Air conditioner compressor clutch. Have you tried starting it with that belt off?
You said that it does it only when cold? I wonder if it could be the A.I.R. pump? It's run by an electric motor and only runs for a little while after cold startup.
Just some ideas
Old Sep 19, 2003 | 10:37 PM
  #17
tailwindxr7's Avatar
I've heard stuff about a 'double idler' pulley. Is that different from the stock one that squeals?
Old Sep 20, 2003 | 01:31 AM
  #18
Mike94ZLT1's Avatar
Just some ideas
Yeah, I've tried running it with the belt off for a minute, my dash lit up like a christmas tree, but no squeal. The squeal would always go away once the car warmed up. Now with that damn Goodyear belt it ALWAYS squeals. I'm going back to a stock GM belt tomorrow. The crank pulley is the only thing left thats still original (other than all the AC stuff) I was thinking about doing underdrive pulleys, think that might help some? I appreciate the help guys but I'm ready to explode. Oh yeah my warranty expired tonight too. Although, thats good and bad (NEW CAM HERE I COME!)
Old Sep 20, 2003 | 11:00 PM
  #19
Racer-X's Avatar
It might be one of your pullys is going bad.
Jim
Old Sep 21, 2003 | 12:59 AM
  #20
Mikie's Avatar
I dont feel its your pulleys at all. Its what the pulley is connected to. I would be willing to bet that you have a bad bearing in one of your accesories. Try this...
Get a can of Belt dressing (Note! I dont reccomend belt dressing as a fix , but as a test to hunt down the problem)
spray sparingly on all of your grooves in your pulleys and then go crank the car. If the squeal comes about then its not the belt.
I also agree with guy above stating you should stethescope it.
You can pick up a stethescope at Autozone and it will really pin point the problem.
Mike
Old Sep 21, 2003 | 03:15 PM
  #21
steelerfan's Avatar
When you say you replaced the belt with a gatorback I hope you mean belts,cause there's 2 there that should be replaced,a long serpantine & a short one also.If you did both then I don't know what else to tell you but if you only did one try the other one too.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
