red line or royal purple?
Old May 22, 2003 | 02:32 AM
GoFast908Z's Avatar
Member
Question red line or royal purple?
For rear differential fluid, transmission fluid, and coolant (if they have it). Which is better, Red Line or Royal Purple? I'm replacing all of them within the next week. Thanks for the help.
Old May 22, 2003 | 09:53 AM
norcalstreet's Avatar
I would choose Redline. I've yet to see a performance shop that doesn't use Redline for rearend fluid. For a T56 I use Redline MTL (I really should be using Redline ATF) and it works fine. Redline doesn't make coolant but they make coolant additivies which have been known to drop your temp down as much as 10 degrees.
Old May 22, 2003 | 10:27 AM
PhantomTA's Avatar
Moderator
Working for a vendor thats sells them both (ramchargers) .. Go Redline
Old May 22, 2003 | 11:08 AM
SunsetWS6's Avatar
Wink
I'm running Red Line in my trans & rear, made a difference. I still use Mobil 1 for oil though....
Old May 22, 2003 | 11:44 AM
GoFast908Z's Avatar
Member
did anyone see the show Horsepower TV, where they changed all the essential fluids in a 2000 SS to Royal Purple and dynoed like 8 more rwhp?
Why redline over that?
Old May 22, 2003 | 02:19 PM
PhantomTA's Avatar
Moderator
because its better oil
Old May 22, 2003 | 09:34 PM
Ferocity02's Avatar
I put Red Line in the rear end and the tranny. The tranny runs a little smoother and quieter, same with the rear end. both oils will give same results. The local store just happened to carry Red Line so thats what I got.
Old May 23, 2003 | 02:37 AM
GoFast908Z's Avatar
Member
well then, unanomous (spelling?) vote for Red Line. Even the all-knowledgable moderator has endorsed it. Well, sounds like I'll give redline a try. Thanks
Feffman
Jul 2, 2015 06:52 AM
carl.froehlich
Mar 13, 2015 12:38 AM
Collector Car
Dec 17, 2014 01:12 PM
brentbrowning01
Dec 16, 2014 06:35 AM
phantasm99
Aug 28, 2002 11:01 PM
