Rebuild bottom end for under 2K???
Old Aug 26, 2003 | 09:35 AM
DeVolk's Avatar
ok my 98Z28 M6 has 60K miles and is knocking on the bottom end...shavings are on the drain bolt (im thinking a rod bearing is on it's way out) w/labor included, stock components, and new rings,bearings, do you guys think it can be done for under 2K??? im thinking i could probably re-use the crank/rods...maybe pistons??
Old Aug 26, 2003 | 08:46 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Rebuild bottom end for under 2K???
well i think you can resleve the LS1- i never built one.
so pistons yes. i'm guessing the rod bearings went so you will probobly want new rods.
crank might be able to be turned.
$2000? HA!
gaskets and machine work and assembly will cost you that much- well 3/4 of it. then add new oil system, timing chain and the whole 9 yards- it adds up REALLY quick. and will ALWAYS cost 2x what you plan.
Old Aug 27, 2003 | 02:02 AM
AL SS590 M6's Avatar
Moderator
A rod bearing wearing out will have no effect on the rods unless you let it go to the point that you break the rod. If the car has a lot of miles then you'll need new .005 over pistons with rings and a hone job. New rod and main bearings, new rod bolts, and either your crank turned or a new crank. You'll also want new cam bearings installed, new cam chain set, and a new oil pump.
All total you might get there for $2000 but I doubt it.
Old Aug 27, 2003 | 11:57 AM
LT-14me's Avatar
Damn, these motors cost alot to be rebuilt hunh? I had an old 350 SBC rebuilt for 1,500. I Supplied most of the parts. How much does a brand new LS1 cost? That might be the route u way want to go, cause a rebuild will barely last over 100k miles.
Victor Lamb
Aug 26, 2017 02:52 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Killer94z
Jan 13, 2015 12:06 PM
RichJ
Sep 26, 2002 09:43 AM
