rear shocks
Old Mar 7, 2004 | 10:31 AM
sandmanusd's Avatar
rear shocks
OK, I am getting really bad squeeking from my rear shocks any time I go over any sort of bump or rock in the road... Do the shocks just need lubing or replacing? and if just lubing.. can I do it myself? using what? and how?
thanks...
Old Mar 7, 2004 | 11:21 AM
CODY BEHNKE's Avatar
Are you sure it isn't a bushing? Shocks rarely make noises unles they are really bad then the tend to clunk.
Old Mar 7, 2004 | 11:30 AM
sandmanusd's Avatar
it probably is the bushing, im not a car guru... just know its squeeking... can the bushing be lubed?
Old Mar 8, 2004 | 10:46 AM
sandmanusd's Avatar
anyone?
Old Mar 8, 2004 | 07:13 PM
These cars are notorious for rear bushing sqeak. You can lube them but some aren't easy to get to. On a couple of mine it was the panhard bar bushings you can un-bolt that.
Old Mar 9, 2004 | 12:27 PM
sandmanusd's Avatar
what do I lube it with?
Old Mar 9, 2004 | 02:01 PM
sandmanusd's Avatar
anyone? please... I dont wnat to have to go pay some mechanic rip off artist 100 bux to do if it takes 5 bux and 5 minutes of my own time to do it?
thanks
Old Mar 9, 2004 | 02:17 PM
If it is the panhard bar (bar that runs right behind the axle) you can take the bolts out and coax it out. Then use a heavy grease inside of the bushing holes. All of the GM rear bushings are rubber with a metal sleeve so after awhile it is metal on metal.
If the control arm bushings are the culprit just hose them with WD40 or something like it. They are a pain to get to.
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
camaro98_speed
Apr 22, 2015 11:26 AM
siguy
Nov 27, 2014 10:07 AM
slothgrant
Aug 22, 2002 03:01 PM
