Question for People with Manual Tran
Old May 19, 2003 | 02:45 PM
RHill22284's Avatar
Angry Question for People with Manual Tran
I have a 2000 Manual Z28 and i was in San Francisco over the weekend and if i got stopped on a hill, I had an extremely hard time getting it to move from a stop.The first time it happend, the car wouldnt move and then made a loud humming noise for a few seconds and slowly moved forward and i barely made it. I made damn sure i didnt get stopped on any more hills that day. Does this mean i need a new clutch? How much money should i be looking to spend to fix the problem.
Old May 19, 2003 | 02:46 PM
Rd95Z's Avatar
How many miles do you have on your car? Have you ever replaced the clutch?
- John
Old May 19, 2003 | 02:58 PM
RHill22284's Avatar
- John
I have around 45,000 miles and no my clutch has never been replaced
Old May 19, 2003 | 03:44 PM
bbentley40's Avatar
Sounds very much like the clutch is wanting to give out on you to me.
Old May 19, 2003 | 03:53 PM
camaro322hp's Avatar
what were the rpm's doing when the clutch wasn't engaging? if the clutch is going out, you should see the rpm's increasing as you give it gas as it would if you were in neutral. in other words, the rpm's would increase rapidly with no power transmitted to the wheels.
Old May 19, 2003 | 04:39 PM
RHill22284's Avatar
thats exactly what happend. how much $ should this cost to fix
Old May 19, 2003 | 04:47 PM
don't know, as i'm still running the original clutch. it depends on the brand and quality of clutch you choose. i'm sure a lot of guys out there have some opinions on which clutch is best...
Old May 19, 2003 | 04:49 PM
RHill22284's Avatar
alright ill do some looking around. thanks a lot for the help
Old May 19, 2003 | 04:52 PM
norcalstreet's Avatar
A clutch install in the Bay Area usually runs about $300. I might recommend Syngery Motorsports in San Jose or Stock to Performance in Concord. Both excellent shops with good reputations.
Unless you're pushing more than 400 HP I would recommend a Star Spec Stage 2 clutch. It's smooth like a stock clutch with good gripping power. It retails for about $450.
Old May 19, 2003 | 10:39 PM
96Z28TealM6's Avatar
RHill22284:
I feel your pain driving in San Francisco. I was out there a couple of weeks ago...I'm sure I messed up my clutch a little going up the hill..not very fun at all!
Old May 19, 2003 | 10:45 PM
Try driving rally style. Use your ebrake to prevent you from rolling back. It's much more effective and puts less wear on your clutch.
Pull the ebrake up, release the clutch and accelerate. The ebrake will prevent you from peeling out into traffic. Slowly release the ebrake as you need to move. Practice enough and you could stay on the edge of the steepest hill without any use of the clutch.
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
A's 91 Z28
Dec 7, 2014 12:09 PM
Lederman1976
Nov 30, 2014 05:21 AM
Jul 4, 2005 05:00 PM
