Pushrods!!!
Old Apr 20, 2004 | 04:04 PM
mooleyz28's Avatar
Pushrods!!!
I have bent pushrods... I was wondering if i put in 7.450 instead of the stock length 7.40, if that would be a problem or what would it do?
Thanks,
John
Old Apr 20, 2004 | 04:15 PM
chpmnsws6's Avatar
i really need to know also. the person who sold em to me said they would since they are only .05 off stock
Old Apr 20, 2004 | 07:49 PM
mrr23's Avatar
seeing as the ls1/6 motors use a torque to specs rocker, it is a problem. the rockers are not adjustable. so everything has to be in exact places and lengths. they changed the rocker geometry by .050"/ so at max lift you may have hit coil bind and bent them that way. also being .050" longer may have hung the valves open by that much also. if the ls1/6 stock rockers were adjustable, you most likely would not have had the problem.
on a side note just had www.vicnihighperformance.com install their 1.89 accelerated lift adjustable rockers, guideplates, pushrods, springs, locks and retainers they want me to drive it for 50-100 miles before strapping it to the dyno to see the results.
Old Apr 21, 2004 | 02:51 AM
AL SS590 M6's Avatar
Moderator
You should never vary from stock length pushrods with a stock valve train. And if putting on milled heads, it would neccesitate shorter pushrods not longer.
Old May 3, 2004 | 10:03 PM
mrr23's Avatar
mooleyz28 - glad to see the pushrods worked for you. where's my money? i know i only shipped you 15 of the 16 i had. accidents happen. and i know it's only $20 but where's my money?
Old May 3, 2004 | 10:25 PM
mrr23's Avatar
thank you for replying to the PM. i'll let you know tomorrow.
Old May 3, 2004 | 10:34 PM
mooleyz28's Avatar
sent the money... just check it out and let me know... If u didnt get it ill just void the check and send another... sorry for the mixup
Old May 3, 2004 | 10:36 PM
mrr23's Avatar
no problem so long as you keep in touch. thanks for the quick replies.
Old May 9, 2004 | 09:26 PM
mrr23's Avatar
mr mooley28 - need to answer my pm about still not receiving the money yet.
Old May 9, 2004 | 10:31 PM
mooleyz28's Avatar
i sent u the money but obvisouly someone is holding my checks... i have now had to send the money twice. Set up paypal or something. Im getting tired of this.
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
94Form
Jul 17, 2015 10:56 PM
