Problem w/ shifter
Old Apr 22, 2003 | 08:38 PM
bombd84's Avatar
Problem w/ shifter
IWell I dont know if I can explain this well but here it goes. I was driving and noticed that the shift **** was loose. Well it turns out that it is not the shift *** loose, but the actual stick that the *** sits on top off. I can tell that it is rotating becase of the little curves in the stick. has anyone else had this problem, how did you fix it?
Old Apr 22, 2003 | 09:01 PM
96SFLZ's Avatar
This is the stock "ball" shift **** right?
Sounds like the leather on the **** has come unglued. That happened on my '96, it felt like I felt like I was turning the **** but it was actually just the leather, the **** was still tight.
Um, buy a new shift ****...that's what I did.
I don't see anyway how the handle itself could rotate like your describing. It could come loose and you could move it back and forth, but you couldn't turn (rotate) it.
Old Apr 22, 2003 | 09:12 PM
kinyu's Avatar
I agree with that. The design wouldnt allow it to rotate, only go back and forth, as in toward the front of your car to the back of your car.
Old Apr 22, 2003 | 09:29 PM
bombd84's Avatar
No, trust me it is rotating. I know for a number of reason. First, i was shifting to second and heard a banging noise. The shaft was turned around because the notch that is supposed to turn towards the dash was facing the back of the car and so that had hit the plastic on the console and made a noise. Also I looked at it closely and pulled down the shifter boot. When I turned the **** the whole shaft was pivoting. Well maybey it is just time for a B&M ripper.
Old Apr 22, 2003 | 09:31 PM
bombd84's Avatar
Well how would I go aboutn tightening this if it is the case. I didnt check to see if it will rotate all the way around.
Old Apr 22, 2003 | 09:51 PM
bombd84's Avatar
mayby a fix
I was looking at install university and I was looking at installing a short throw shifter. There appears to be two bolts that look like they hold the shifter shaft in place. I wll try to get a look at these tomarow and see if they need tightening.
Old Apr 22, 2003 | 09:59 PM
Ferocity02's Avatar
I don't know what these other people are talking about but ya, it sounds like the whole shifter stick is loose. Just act as if you are doing a shifter install and get to those two bolts you speak of and check them out. If they are loose, put on some thread lock.
Also, you might want to pull on the stick straight up and see if it comes off, if it does, definitely those two bolts. Good Luck!
Old Apr 22, 2003 | 10:20 PM
blkss01's Avatar
-Remove the coin holder in your console and remove the 2 7mm
bolts underneath it.
-Unscrew the shift ****
-Take out the ashtray and the little light under it.
-pull the console up and out
-Tighten the bolts holding your shifter stick onto the shifter base.
14mm I believe? Anyways, If one is missing (common that I've seen) find a bolt that will fit, otherwise really tighten the one bolt down. BUT BE SURE NOT TO PUT PRESSURE ON THE GEARBOX!!! HOLD THE STICK WHILE TIGHTENING THE BOLT! LET YOUR HAND TAKE THE PRESSURE!
Hope that takes care of your problem!!
Old Apr 23, 2003 | 12:35 AM
Flat_Tire_'s Avatar
While you're at it, install a Pro 5.0. A black anondized Z28 shift **** from Thunder Racing wouldn't hurt either ;-) check out the link in my sig to see it.
Old Apr 23, 2003 | 02:53 AM
dj haf's Avatar
truu, go get yourself a ripper man fo0k the stock shifter, you'll have more fun with the ripper
Old Apr 29, 2003 | 06:26 PM
bombd84's Avatar
Well I had the chance to look at it this weekend. I took off the consol and everything. The shifter DOES spin around. There are actually no bolts of anything that hold your shifter stick in place. It seems that they use friction between the shifter shaft end and the socket it sticks into. Both are covered in rubber. I guess that mine got some sort of lubracant in it or something. So it looks like I have to buy a new one
Old Apr 30, 2003 | 12:19 AM
AL SS590 M6's Avatar
Moderator
Get a Pro 5.0 they are awesome. And trouble free for 5 years now.
RUENUF
Mar 13, 2016 03:39 PM
BigWil
Mar 29, 2015 12:24 PM
mattstrike
Mar 11, 2015 07:33 PM
karpetcm
Feb 9, 2015 09:21 PM
tds1213
Nov 27, 2014 12:55 PM
