View Poll Results: How much oil do you burn ?
.25 - 1 quart in 500 miles or so
0%
.25 - 1 quart in 1000 mile or so
5.56%
.25 - 1 quart in 2500 miles or so
33.33%
.25 - 1 quart in 4 - 5 K miles
0%
None ! :<}
11
61.11%
Multiple Choice Poll. Voters: 18. You may not vote on this poll
Poll ! How much oil does your motor use ?
Old Jan 24, 2003 | 08:08 AM
NEWBIE T/A's Avatar
Question Poll ! How much oil does your motor use ?
Me ?
I figure I am average - the car, too.
This last oil change was after 4000 miles - I had used 10W30 Wal Mart Full Synthetic.
I burned ~ 3/4 qt - no low oil lights or anything , and I wa still within the cross hatch area of the dipstick.
These engines apparently burn some oil by design ( low tension piston rings, high compression, etc.) , so I am not concerned , but curious.
Thanks !!
Britt
*Edit*
birdblack brought up a valid point - my car sees a good deal of "spirited" driving.
However, I assume most LS1 owners do so as well.
Old Jan 24, 2003 | 08:35 AM
lastZ's Avatar
i have a 2002 Z with around 6000 miles and i dont burn a drop, my friend has a 200 SS and the same with him!
Old Jan 24, 2003 | 08:45 AM
oldBones's Avatar
Talking
I own a Lt1 and I burn about a 1 quart every2000-1500 miles, but I also over fill my motor by a half quart.
Old Jan 24, 2003 | 08:46 AM
PhantomTA's Avatar
Moderator
none..
2 new motors and even after the rebuild.. none
Old Jan 24, 2003 | 10:22 AM
XKnightRider's Avatar
I have almost 7K miles on my '02 and it's hasn't burned a drop yet.
Old Jan 24, 2003 | 10:55 AM
birdblack's Avatar
I find that I tend to use a little oil with "spirited" driving around town but on a recent trip to FLA, cruising at 85-90 @ 1800 - 2000 rpm on the interstate, it hardly used a drop.
Old Jan 24, 2003 | 11:09 AM
White_94_TA's Avatar
9K miles and None.
Old Jan 24, 2003 | 11:24 AM
KDawgY2kSS's Avatar
Generally use between half a quart and a quart of synthetic every 2500 miles. BTW, have 56k on the motor. Most of my driving is definately defined as " spirited " Many years from now I will probably have to have some therapy to help reduce this chronic case of lead-foot-itis I have developed since getting this car!!
Old Jan 24, 2003 | 12:50 PM
2000TA's Avatar
i dont burn any oil but I dont get on it all that much
Old Jan 24, 2003 | 01:30 PM
nikkev's Avatar
My '98 doesn't burn any oil during normal driving.When I go to the track 3-4 times between changes I'll burn about 1/2 quart.
Kevin
Old Jan 24, 2003 | 05:03 PM
99blackSS's Avatar
I am kind of worried, I drive my car like I stole it and it has 70k miles and doesn't burn a drop. The dip stick keeps showing that have the same amount I put in it but my change oil light has been comming on ever since I changed my oil, I think that may be a sensor problem though.
...yes I have tried resetting the light
Old Jan 28, 2003 | 04:52 PM
warner's Avatar
My 95 has 47k on it and doesn't burn a drop. This is running synthetics which will definitely not burn like dino oil.
Old Feb 1, 2003 | 08:49 PM
pearlpurple's Avatar
85,000 plus miles not a drop (knocks on wood)
Old Feb 4, 2003 | 07:36 AM
Njgunslinger's Avatar
i have a 2000 Transam and my check oil light comes on after a 1000 miles after oil change, not sure how low your oil needs to get before that light comes on. Im actually taking the car to the dealer today for an oil comsumption test since the care is still under warranty.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
transam_388
Mar 15, 2015 11:53 AM
Donwest22
Parts Wanted
Dec 18, 2014 11:10 AM
