Please Don't Kill Me
Old Mar 1, 2004 | 09:19 AM
StormSigma's Avatar
Another pressing question.
When I start my Z28 in the morning, I'm hearing a really loud "squeeky wheel"(sound speeds up when I get on the gas) noise, that's loud enough to be easily heard over the rumble of the engine. It only subsides twenty minutes or so after the car warms up, and it slightly intensifies if I turn on the AC.
Anyone have any idea what it might be? I don't have any warning lights coming up, the car's running strong as ever, and all the gauges are showing normal.
I'd give anything to get it to stop, it didn't use to do this, but somehow recently has acquired it. And it's not the belts, both belts are new. It's embarrassing to ride past the apartment complex bus stop with this loud squeaking going on, making my LS1 sound like a 1987 Buick on a thirty degree winter morning.
Old Mar 1, 2004 | 09:31 AM
lifbcracker's Avatar
hmm
It deffinatly sounds like the serpintine belt, if you just got them then i suggest getting some lithium grease or some kind of grease of some sort and spray a lil on the pulleys and belt, it should stop. Other then that something could be loose.
Old Mar 1, 2004 | 10:06 AM
95GRNZ's Avatar
Thumbs up
Since yours is a 99, I'd be willing to bet it is your idler pulley on its way out.
Do a search with idler pulley in this section and you'll come up with lots of info.
TS
Old Mar 1, 2004 | 10:11 AM
teke184's Avatar
i second the pulley problem.
i would swap to a new belt first...nice cheap and easy possibleremedy
pop the hood and see if you can isolate the sound source.
another thought would be your air pump for emmissions, it's located behind the driver side headlight...listen for it, you'd be able to tell if that's where it's coming from
Old Mar 1, 2004 | 11:54 AM
StormSigma's Avatar
Sounds good. Also, the "idler pulley", is that something easily replaced? I am admittedly not very good mechanically as yet. How much would such a part cost?
However, to respond about the belts, both of them are brand new, roughly a week old. I don't think swapping them would do anything.
Old Mar 1, 2004 | 12:21 PM
cop_camaro's Avatar
Idler Pulley::
Replaced mine and Gm part was $48 for complete pulley assy.
Smart me, I bought a bearing for the pulley and it cost $46.
I had to have a friend press out the old bearing and press in the new one.
If I had it to do over would just buy the one from GM!
Just my $.02 worth!
This correct my squealing and was a simple job, about 15-30 min.
Old Mar 1, 2004 | 12:47 PM
teke184's Avatar
should just be a couple bolts.
the hardest part will probably be getting the belt routed correctly over the maze of pulleys and tension wheels
Old Mar 1, 2004 | 12:58 PM
StormSigma's Avatar
Well, that's the easy part. My dad and I changed the belts in roughly seven minutes. I guess I just need the part. I wonder if it's covered by my warranty? I paid for an extended bumper-to-bumper warranty when I bought the car used through my credit union. Hmmmm...might be worth checking out.
grabbem88
Apr 16, 2015 06:57 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Zomie
Sep 2, 2002 09:04 PM
Zomie
Sep 2, 2002 09:01 PM
Brent94Z
Mar 21, 2002 04:44 PM
