Peak Power!
Old May 4, 2004 | 07:45 AM
roadkillZ28's Avatar
Peak Power!
My queries are the following:
how and when the rated hp of my car can achieve; is it during the peak speed?
is it during progressive speed? is it during climbing or ascending motion?.
is it during progressive acceleration or is it with relation with the engaging of the x-mission into the differential????
Appreciate any reply
Old May 4, 2004 | 10:26 AM
Klypto's Avatar
its at a given rpm.... if i read your question right...
around 4500 maybe? i dont remember, check out some dyno graphs, to find out...
cory
Old May 4, 2004 | 03:04 PM
mullettour's Avatar
Being stock the peak horsepower will be somewhere around 5500-6000. So anytime you are in that rpm range at wide open throttle you can make peak power in any gear. It's a little difficult to understand your question so if that isn't what you're asking about please clarify.
Old May 6, 2004 | 07:17 AM
hmm,..
okay, is the torque and power peake occur simultaneously ...?
at what RPM ... or are they occur at different RPM..? what basis 550 foot-pounds per second in one hp?
what actually accelerates a car ... is it because of the torque generated by the engine or the torque applied by the tires to the ground?
I think now is clear
Old May 6, 2004 | 09:36 AM
V6toZ28's Avatar
Originally posted by roadkillZ28
hmm,..
No ... torque low end RPM/HP high end RPM
It's the formula for HP ... no more basis for it than there is for 3 feet in a yard or 4 quarts in a gallon ... it just is.
Power to the ground ... no power at the wheels, no move the car ...
MadMav
Jun 15, 2015 09:51 PM
blmw
Jun 14, 2015 05:20 PM
MadMav
Jun 8, 2015 11:38 PM
XtremeLt1
Sep 13, 2002 08:50 PM
