pcv
Are you sure that's where it's coming from?? Never heard of one leaking before. As far as a PCV system problem causing it to leak it's doubtful.
PCV system problems on LS1s generally cause high oil consumption and oil in the intake manifold.
I have checked the front seal and its ok. There is a trail of oil leaking from the valley that just under the T.B. that leaks down to the front passenger corner of the oil pan and then trails all the way to the trans. I checked it with the car runnung and I see oil bubbling from the valley cover. I was wondering if there is too much pressure blowing it out from a bad pvc, or just a bad valley gasket.
mineralwater
Oct 17, 2003 05:34 PM
asianice25
Apr 2, 2003 11:42 AM
