passing emissions
Old May 21, 2003 | 10:29 PM
in2ta's Avatar
passing emissions
How does everyone with the built f bodies pass emissions are you luky and just don't have emmision testing
Old May 21, 2003 | 10:51 PM
Ferocity02's Avatar
In California, it's all about the bribe....eerrrrrrr.......tip
It's easy to pass emmisions, but in Cali, we can't have long tube headers
Old May 21, 2003 | 11:52 PM
Jon98's Avatar
in pa we have testing, its really easy to get passed if you think alittle. first off here, if you drive under 5000 miles per year you are exempt. so if your car "stays" under 5k miles a year you never have to get it tested.
lots of people here get fake stickers which apparently a lot of cops can spot (i don't know how they do?) but then you just get fined. i find that a lot of people get fake stickers caus they are less then half the price of an actual inspection. others buy real stickers. and with afew bucks, and asking around, you can definatly find a shop that you can't fail at
Old May 22, 2003 | 12:59 PM
NEWBIE T/A's Avatar
Lightbulb I dunno about "built", but ...
With the new OBDII type testing in Texas, all they do is plug into the diagnostic port while the car is running.
No trouble codes/lights = Pass !
The only mod that might have even affected the 'puter was the HPP III , and it is certified as emissions legal.
Heh heh - don't even have to change the oil before ya go like with the treadmill tests, which are still done here on the '95 and older cars ( pre OBDII ) .
Sad part is, they still charge the same $ 40.00 for either test, pass or fail.
Britt
Old May 22, 2003 | 03:00 PM
Schismblade's Avatar
Good, since i'm in texas, i'll just reset the PCM before I get the emissions tested. If it's giving me crap that is.
Old May 22, 2003 | 03:27 PM
stik6shift98's Avatar
obd 2 here in il as well
guys with heads and cam pass all the time
Old May 22, 2003 | 04:10 PM
RobertoZ28's Avatar
"heh heh...Beavis passes emissions all the time...heh heh."
"Shut up fart cracker"
Old May 22, 2003 | 08:10 PM
ChrisLS1Bird's Avatar
Re: I dunno about "built", but ...
Britt
I'm curious about this..if you show up with a nasty loping cam and the smell of gasoline, can you pass the Texas test as long as you don't have any codes? How about with an off-road pipe?
Old May 22, 2003 | 09:19 PM
Capn Pete's Avatar
Lightbulb
Wow! The OBDII test sounds pretty cool! Here in Ontario we've gotta run the car on a "treadmill" ( ) and it's sorta tricky to get around it..........not impossible mind you, but I'm not sure what could be done with a newer fuelly car to clean it up? I know that when I had my '81 Z28 tested (with the 383) it failed miserably the first time, but with a little "tweak" of a screwdriver, adjusting the amount of fuel flow, it passed with flying colours!!! (shhhhhhhh, don't tell anyone though).
Old May 22, 2003 | 10:07 PM
in2ta's Avatar
well I have to have obd2 but I have all options o2 simms people and real stickers I have a 112 came I am about to install and I plane on adding heads I just don't want to get bit in the a** with it I guess I will just see if I get any codes The thing with obd2 testing is that it works like a hypertech it reads your vin #
Old May 23, 2003 | 07:25 AM
NEWBIE T/A's Avatar
Lightbulb There was no sniffer that I noticed ...
So, as far as I know you could pass w/ the above mods.
However - there has got to be some trick - maybe a visual inspection if the inspector has questions - ?
Just dunno.
I know you would not be able to w/ a 95 or newer due to the treadmill w/ sniffer.
Bastages - my '91 Suburban barely squeaked by last time 'round 'cuz they made the treadmill test tougher to pass for the older cars. Before, they just ran it stationary at ~ 1000 RPM & 2000 RPM.
Now, the treadmill acts as a load - and they lowered the specs.
For $40.00 ( $ 39.95 I think is the exact amount ) the least they could do is give me HP readings at those speeds ...
Britt
Old May 23, 2003 | 11:00 PM
BadAndy743's Avatar
Here in GA, tESTING IS 25 BUCKS, pass or fail. With OBDII they plug in ad if you don't have any abnormal codes, you are passed. In our cars, The puter does not give the checker any statistical info, as on the treadmill. The computer simply gives a "go, No Go" reading of Catalytic converter function. If the guy wanted to be a **** head he could give you a visual inspection, but who wants to be a ********?
Old May 24, 2003 | 11:17 AM
rncotton's Avatar
Memphis hasn't gone to OBDII yet, but it's in the works. Until then, we have to go to one of the three city owned inspection stations, wait in line for 2 hours, and have the sniffer test.
So, until OBDII starts up, there isn't much we can do to get around the inspection other than have your car registered outside the city limits.
So, you live in the city, but your car lives at a friend's house out in the county.
Old May 25, 2003 | 08:04 PM
in2ta's Avatar
So does anyone have stage 2 heads and cam and can still pass the OBDII
Old May 25, 2003 | 09:07 PM
BadAndy743's Avatar
A guy in my club did. With headers too. Plug and go.
David Dempsey
Mar 12, 2016 12:42 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Cam's maro
Aug 11, 2015 07:45 AM
