overheating & a/c issues
Old Oct 12, 2007 | 01:16 PM
sikkz28's Avatar
I looked around and couldn't find an existing topic on this...here's the issue...
I have a 2000 z28 with roughly 115k miles on it, since the temp drop into fall i've been cruisin with the windows down, went to turn the a/c on the other day and got nothing but hot air...
also, the temp on the car has normally been at 210 while cruising and recently it's been going above 210, nothing to high...yet....
any help with this would be appreciated...
Old Oct 12, 2007 | 01:35 PM
SSpdDmon's Avatar
Have the fluids ever been changed (coolant, A/C, etc.)?
When you turned on the A/C, did you have the temp **** in the blue or in the red? (Sounds silly, but some people have actually thought their A/C was busted and that's all it was. )
Old Oct 12, 2007 | 01:40 PM
sikkz28's Avatar
going to flush the coolant this weekend, i haven't done it in the 3 years i've had the car, and it was on blue...but i know what you mean
Old Oct 13, 2007 | 05:59 AM
AL SS590 M6's Avatar
Moderator
I wold check and see if the cooling fans are working correctly.
Old Oct 13, 2007 | 03:08 PM
sikkz28's Avatar
turns out the a/c line that goes from the evaporator to the condenser has a crack right at the condenser...another $43.70 and i should be good
HectorM52
Jun 23, 2016 08:42 PM
timmy39120
May 8, 2015 11:41 AM
warmeck
Apr 16, 2015 05:50 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
alphaauto
Feb 5, 2015 05:25 PM
