View Poll Results: Which mod?
LS6 Intake
33.33%
853 Heads
66.67%
Voters: 6. You may not vote on this poll
Which one will I see more gains with? LS6 Intake vs Ported 853 Heads
Old Nov 13, 2007 | 03:32 PM
  #16
Mike96z's Avatar
and as far as RP sheeting off of the metal? its been tested and RP has one of the highest film strengths of any oil made.
Old Nov 13, 2007 | 06:51 PM
  #17
Mike94ZLT1's Avatar
Film strength doesn't mean **** in a test conducted at room temperature in an environment not found in an engine. I'm sure you are referring to scratch tests such as this one - http://www.animegame.com/cars/Oil%20Tests.pdf
They're pure bull****. Look on the oil drop forums. Check on LS1tech for posts by Patman. Check with Blackstone labs, a company that does oil analasys. Royal Purple MOTOR OIL sucks, plain and simple. And oil sheeting off of metal has absolutely NOTHING to do with film strength. What that means is when the parts spin at high speeds the oil is flung off. It reduces horsepower loss by less weight on the crank and other moving parts, but at the same time it is also not there to lubricate.
Old Nov 13, 2007 | 07:05 PM
  #18
Greed4Speed's Avatar
and Royal Purple isnt junk, its how you use it and the idiots that dont correctly use it are the ones who blow their **** up.
I have to ask, how are people not using motor oil correctly?
Old Nov 14, 2007 | 12:22 AM
  #19
Mike96z's Avatar
alright, got the heads in my hands, the porting is badass, fully ported and polished, will post pictures of work on here. I think its the way to go for now. I play on installing the heads when I get the valve covers and brackets but while im at it, will install the LS7 lifters and probably some good springs. Then comes the cam and intake.
Old Nov 14, 2007 | 12:23 AM
  #20
Mike96z's Avatar
using wrong weight, using racing oil when it shoudnt be used or racing on the hp motor oil, royal purple has many different oil types for many different purposes.
Old Nov 14, 2007 | 07:18 AM
  #21
Mike96z's Avatar
you cant see how good it really is in the pics but here are some pics:
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
rcajun86
Jan 30, 2015 01:56 PM
95chwagon
Jan 13, 2015 09:19 PM
RedLineRev
Jan 23, 2003 03:51 PM
