View Poll Results: Which mod?
LS6 Intake
33.33%
853 Heads
66.67%
Voters: 6. You may not vote on this poll
Which one will I see more gains with? LS6 Intake vs Ported 853 Heads
Old Nov 12, 2007 | 11:11 PM
Mike96z's Avatar
Alright, should I go with the LS6 Intake on my 98 LS1? or the Ported 853 Heads?
Currently I have a 98 LS1 from a SS Camaro in my 96, its a M6 setup, current mods are below. Just wanted to see from which I would see more gains from. Not sure how well a set of ported 853's would flow but hopefully they would flow pretty good. Does anyone think they would flow like LS6 heads? The heads were milled a little I think to raise the compression. My car has the stock 806 castings which I heard, stink.
Specs:
5.7L 346 ci. LS1 (98 SS Camaro Engine)
370 HP @ 5500 RPM est
385 TQ @ 4500 RPM est
Mods:
-Hurst Competition Plus Short Throw Shifter
-F1 Lightweight Flywheel
-Walbro 255lph Fuel Pump
-Hooker Super Comp LT Headers
-G2 Cold Air Intake
-K&N Air Filter
-Ported MAF Sensor
-Rebuilt T-56 w/ Beefed Shift Forks
-180 Thermostat
-Copper Header Collector Gaskets
-No AIR
-No A/C
-Skip Shift Delete
-6,500 Rev Limit
-No Governor
-No Cats
-Royal Purple 5w30
-LG Performance 2.5 in. Lowering Kit
-ES T/A Mount
-ES Tranny Mounts
-X-Pipe w/ Dynomax Bullets
-Centerforce Dual Friction Clutch
-LCA Relocation Brackets
-Powerstop Coated Cross Drilled Rotors
-Royal Purple HP 5w30
-Hurst Hot Shift HP ATF
Apperance Mods:
-17x11.0 Black Grandsport ZR1's 315/35ZR17
-Nitto Drag Radials 315/35ZR17
Old Nov 13, 2007 | 07:30 AM
AL SS590 M6's Avatar
Moderator
Any well ported LS1 heads will out flow stock LS6 heads by a bunch.
You will gain the most with the heads but the intake will increase your hp a lot when added to the ported heads. Just keep in mind that you'll need new tappet covers and coil mounts.
And get that RP junk oil out of there.
Old Nov 13, 2007 | 07:42 AM
teke184's Avatar
but ported heads on a stock cam...not sure how much you would honestly gain.
i say find out.
Old Nov 13, 2007 | 08:10 AM
Mike94ZLT1's Avatar
i say find out.
Don't waste your time, you will gain more from a cam on stock heads than you would with heads on a stock cam. You're going to want at least an LS6 intake either way though.
Old Nov 13, 2007 | 08:28 AM
Mike96z's Avatar
RP isnt junk lol. I understand the LS6 intake would probably give me more gains in the short run but heads will give me more gains in the long run. Either way, if you have heads the intake will restrict you, if you have an intake the heads will restrict you, if you have all of those, the tb will restrict you.
Old Nov 13, 2007 | 09:12 AM
Kraest's Avatar
Retired
A cam-swap will make more power than either of those.
I'd get an LS6 intake manifold first if you are only picking between the intake manifold or the heads.
Old Nov 13, 2007 | 09:49 AM
RE AND CHERYL's Avatar
Hey Mike
Until your ready to replace the cam I would leave the heads alone. The intake would be your best bet now as the heads are worthless without a better cam, and once you install the heads/cam your gonna need a better intake anyway.
LS6 intake with ported TB is my vote for the first mod.
Re'
Old Nov 13, 2007 | 10:21 AM
Mike96z's Avatar
I know on these engines you have to pull the heads to install lifters, but I thought you didnt have to pull the heads to put in a cam. Thought the lifter trays kept the lifters from falling down into the lifter bore. Correct me if im wrong.
How much would a set of ported 853 heads sell for?
Old Nov 13, 2007 | 10:28 AM
Kraest's Avatar
Retired
No, you don't have to pull the heads to install a cam.
No idea how much they would sell for. It depends on how much they are worked and who did them.... Anywhere from $300-1000.
Mike
Old Nov 13, 2007 | 11:27 AM
Greed4Speed's Avatar
Ported 853 heads don't tend to go for much $ unless they've been worked by someone like GTP or MTI.
Old Nov 13, 2007 | 12:02 PM
Mike96z's Avatar
seems like i may be going with the heads first, but i wont install them until I buy some LS7 lifters and probably some springs, then Ill swap on a LS6 intake and cam.
Old Nov 13, 2007 | 02:00 PM
Mike94ZLT1's Avatar
RP isnt junk lol.
Yes, it is.
https://www.camaroz28.com/forums/sho...d.php?t=553942
Old Nov 13, 2007 | 02:01 PM
Mike94ZLT1's Avatar
And tune it 3 different times? That makes alot of sense!
Old Nov 13, 2007 | 03:27 PM
Mike96z's Avatar
well not everyone has money growing out of their *** to buy it all at once and I dont wanna wait forever to put the parts on
Old Nov 13, 2007 | 03:30 PM
Mike96z's Avatar
and Royal Purple isnt junk, its how you use it and the idiots that dont correctly use it are the ones who blow their **** up.
