Royal Puple
Old Nov 9, 2007 | 09:04 AM
Robert 98's Avatar
Royal Puple
Anyone have any opinions on using Royal Purple Synthetic in a 98 LS1?
Old Nov 9, 2007 | 09:05 AM
Kwiksilverz28's Avatar
I use it in the transmission and rear end. I use Mobil 1 in the motor.
Old Nov 9, 2007 | 09:36 AM
teke184's Avatar
too expensive
won't be any better than a good name brand synthetic oil
Old Nov 9, 2007 | 11:16 AM
johnny6's Avatar
It works good on my differential, i use mobil1 on engine but RP is really pricey.
Old Nov 10, 2007 | 12:14 AM
zo6vette's Avatar
I use royal purple in my transmission and rear end.
Old Nov 10, 2007 | 07:12 AM
AL SS590 M6's Avatar
Moderator
After pulling the pan on my 00 with just 2 seasons (300 miles, 200 passes) of running RP, fresh every season and seeing all the black residue. I'll not be using it in my engine again.
Old Nov 10, 2007 | 02:35 PM
Kraest's Avatar
Retired
It'll perform the same as any other full synthetic oil.
Old Nov 11, 2007 | 09:28 PM
greenmachinedriver's Avatar
royal purple imo has a problem with sludge or residue. mobile 1 is the way t go.
Old Nov 11, 2007 | 09:33 PM
matLT1's Avatar
I would not recommend synthetic fluids for anything that uses clutches (i.e. automatic transmissions or clutch-type limited-slip differentials).
Old Nov 12, 2007 | 07:27 AM
That is what manufacturers are calling for a lot of times. Both my Avalanche and my wife's Scion transmissions call for Synthetic.
Old Nov 12, 2007 | 08:03 AM
Moderator
98 Z28s have a clutch type Auburn posi and have synth in them from the factory and calls for synth as the replacement fluid.
Aftermarket clutch type posis like the Eaton HD specifically warn not to use synth.
So blanket statements like yours are not valid. Each has to be case by case.
Old Nov 12, 2007 | 03:01 PM
Mike94ZLT1's Avatar
No, Royal Purple blows. Read the whole thread, then look on LS1tech. http://forums.corvetteforum.com/show...ghlight=AMSOIL
I run Redline Synthetic 10W40 with a WIX filter in my Vette. It's 9 bucks a quart, but consistently proven to be the best. And to the people bitching about the cost of oil... Do you change your oil every other day or something? If you change your oil every 2 or 3 months who gives a **** if a good quality oil change is $30 or $40 more?
Originally Posted by TLewis4095
Hmmm Only bearing failures we saw in our race engines were w/RP. Reher Morrison says the only way you can use RP in a Pro Stock motor is to change it after every run. We have run M1 in our Alky drag motors for 7 years w/out issue, but have seen 2 failures w/RP.:cheers:
We have had good luck with M1, Lucas, Amsoil, but RP has resulted in engine failures that the only cause was lubrication failure. I don't care what any "tests" show, we run $18-22,000 Alky motors and compete all over the Eastern US in Top Dragster, Super-comp, & Super Pro....and have several close friends who run Pro-Stock (Dave Connolly, Jeg Coughlin, etc.) and aside from a few extra HP from the oil sheeting off the metal so fast, RP will not protect our 8,000 RPM race motors. In fact we will NOT warranty our performance builds if RP is used. We run our race motors at the ragged edge & we have to rely on good protection, RP does not. Anyone that wants to argue the point just put up $20k for one of our new race motors & we run one on M1 & one on RP, full load dyno runs and see which ones lasts. End of discussion.:cheers:
TLewis is the owner of RevXtreme in Tampa, a respected LS1 builder.
Old Nov 12, 2007 | 09:14 PM
psychocabbage's Avatar
I believe I have been saying this for the past 7+ years on here.. RP leaves a horrid residue and no engine builder I know would ever use it..
Old Nov 13, 2007 | 07:51 AM
teke184's Avatar
but but.....i saw on Horsepower TV....
Old Nov 13, 2007 | 06:36 PM
87slyroc's Avatar
good for farm equipment, thats about it.
