oil in LS1
Old Sep 27, 2003 | 09:52 PM
sLpRoCks's Avatar
Angry oil in LS1
Hi Everyone,
It was 1000 miles ago when I had my oil changed by Shell gas station near my house. I checked my dipstick the other day and it now has about 1/3 left between where the top of the line is where you can fill it too and where it says ADD. I need to top this off now and I don't know what kind of oil they used. What should I put in there and can I do this while the engine is cold ( add a little at a time until it gets the the top)?? Thanks
Old Sep 27, 2003 | 10:23 PM
MarcoZ's Avatar
I check mne by the manual the car came with, let the car run a while, turn it off for a few minutes so the oil can drain back to the pan, then check it. I am also having problems with my oil, it said that i needed to add 1 qt so i did and all is fine, but i have found no evidence of oil leaking anywhere. I hope it is nothin gmajor
Old Sep 27, 2003 | 10:26 PM
sLpRoCks's Avatar
same thing here with my 99 z28 I had it at two different carmax service centers and there is no evidence of leaking oil and they just tell me that all of these cars burn oil and some worse then others? just hope its not messing up ne other parts?
but ne ways can u mix oils? like say i have 10 w 30 in there now (cause i dont' knwo whats in there) and add some syntech
Old Sep 27, 2003 | 10:34 PM
99blackSS's Avatar
I would assume they use there shell brand of oil. Most likely it would be there 5W-30. I would go back to that gas station and ask what kind of oil they use to be sure.
Old Sep 27, 2003 | 11:10 PM
Bluntdogg's Avatar
That's it. Some leak a lot, some alittle. It's no big deal unless you're adding more then a qt between changes.
Old Sep 28, 2003 | 05:11 AM
My84Z's Avatar
all ls1's burn oil the more you hammer on it the more it drinks it is the gay as egr on these things. nothing wrong with your engine although i do suggest you start using synthetic oil and chenging it yourself.
Old Sep 28, 2003 | 10:05 AM
Slappy3243's Avatar
None of them leak oil, that would be a problem. They burn a little oil though when you get on it. I just got my LS1 and I am going to change my oil this week and I will see what happens.
-Adam
Old Sep 28, 2003 | 10:43 AM
Bluntdogg's Avatar
Meant to say "burn", not leak. Yeah that would definitely be a big problem.
Old Sep 28, 2003 | 07:20 PM
Geezer powered's Avatar
Hey thats a little price you guys have to pay for having 300rwhp stock. Big deal you have to add a qt between oil changes. Just a design flaw no big deal. Stop crying.
Old Sep 28, 2003 | 10:30 PM
Timberwolf's Avatar
There is a TSB regarding the LS1 oil consumption. I believe it is due to ring tension. There's a blurb about it in this months Chevy High Performance Magazine
Old Sep 29, 2003 | 01:16 PM
NEWBIE T/A's Avatar
Lightbulb Yes, you can mix.
Most Syn oil labels that I have seen mention how they are fully compatible w/ dino oils.
No problem.
My '99 SS burns about a 1/2 qt every 3K.
Since our cars hold 5.5 qts, what woould you do w/ the other 1/2 qt from the oil change anyway ?
I think GM specs are that if it is using a qt or more every 500 miles, there is a problem.
Oh, is your a M6 ? Apparently they tend to use more oil than an A4 - depending upon driving style.
Britt
Old Sep 29, 2003 | 01:59 PM
2001NBMZ28's Avatar
You can view the GM TSB on oil comsumption/guidelines here: http://web.archive.org/web/200112181...regg/gmsi.html
Old Oct 1, 2003 | 12:24 AM
mebanditws6's Avatar
Try a new PCV valve. Some of these were bad, and a new one may help or correct the oil consumption. But most of the time LS1's will burn some oil because of ring tension. This is no design flaw. By letting a little oil get past the oil ring, it serves to offer some extra lubrication. Ford reportedly did this on the HO 5.0's on the fox body stangs.
Jason
rideordie
Nov 5, 2019 04:52 PM
Fastbird93
Apr 9, 2016 07:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
captcorvette
Mar 7, 2015 12:37 PM
