oil filter change intervals
Originally posted by AL SS590 M6
I aint puttin no $3 filter on my car.
AC Delco PF44. If you are paying more, what brand are you using? The only other easily available one I would use that costs more would be the Mobil 1 filter...
The K&N HP2006 is a great filter that flow better than the Mobil1-206. Once I replaced the Mobil 1 to the K&N, the oil pressure is higher and that is a good thing. The K&N Filter great too and is less restrictive to oil flow.
When you said $3 filter all I could envision was a discount store brand because we can not get ACs for $3 around here.
Pressure is a direct result of resistance to flow. So the K&N is flowing less
And yes, check out www.bobistheoilguy.com. You'll find a lot of good info on oil, oil filter, and oil change intervals there... if you're changing your synthetic oil before 5k-6k, then it's really not worth the price of the synthetic since you're not getting the most out of it.
I change mine every 6k or every 6 months, whichever comes first... and for me, it's 6 months since my Z28 is only driven a couple of times a week.
Jul 4, 2005 05:00 PM
