oil drain plug wont budge
Old Jan 2, 2004 | 08:28 PM
98formyws6's Avatar
Angry oil drain plug wont budge
i was trying to change the oil on my 98 formula tonite but i cant seem to get the damn oil drain plug to budge. any suggestions? (and yes i done it before tons of times on my 2000 T/A and my moms and sisters cars). thanks
Old Jan 2, 2004 | 08:30 PM
99blackSS's Avatar
Use a a pole or something similar to apply more leverage on it. Be sure not to tighten it so hard next time.
I used the pole from my floor jack.
Old Jan 5, 2004 | 12:20 PM
steelerfan's Avatar
Ditto,had to slip a breaker bar that I made from a piece of pipe I had laying around to get more leverage,otherwise it wouldn't budge.Tried not tightening as hard after that but I've needed the breaker bar every time anyway.A mechanic friend told me it has something to do with the oil pan being cast aluminum instead of steel & the steel drain bolt expand & contract at different rates.
Old Jan 5, 2004 | 10:44 PM
96LT14u2Nv's Avatar
ditto on the breaker bar. mabey some WD40. just hand tighten it next time.
Old Jan 6, 2004 | 07:41 AM
NEWBIE T/A's Avatar
Lightbulb Alternative to a breaker bar (brute force).
Try taking a 1/2" ratchet w/ the appropraite socket and tap the ratchet (solidly) w/ a hammer in the direction you want to go w/ the ratchet.
The idea here is that sometimes vibration is a better tool than force. Kinda the same principle as w/ an air ratchet.
Mine was dam tight, too the first go round - these plugs don't take much torque due to the o-ring seal (like 15 foot lbs, I think) so I have gotten into the habit of just snugging mine up , plus a wee bit.
Good Luck !
Britt
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
