oil
Old Feb 21, 2004 | 01:20 AM
GoFast908Z's Avatar
Member
oil
where can I get some Royal Purple oil?
Old Feb 21, 2004 | 06:28 AM
02CamaroSS's Avatar
IMO just use mobil 1 if u want true synthetic. It's not worth the hassle to search for royal puprle.
Old Feb 21, 2004 | 06:30 AM
SilvercamZ28's Avatar
I get mine through JEGGS ... it ships out quick but is a little more expensive than Mobil 1 .... I like it though.
Old Feb 21, 2004 | 09:56 AM
Buffdaddy's Avatar
Mobil 1 would work just fine.
Old Feb 21, 2004 | 05:02 PM
iateyour5.0's Avatar
I get mine from a place called Automotive Engineering, but we're on opposite sides of the nation so I doubt you have one. And I only use the transmission fluid and rear gear oil. Oil....Mobil 1 all the way.
Mike
Old Feb 22, 2004 | 02:25 AM
GoFast908Z's Avatar
Member
well i always use mobil 1 , and I just wanted to try Royal Purple once.
Old Feb 22, 2004 | 03:58 PM
Greed4Speed's Avatar
Mobile 1 may not be TRUE synth
Here is some info from another board:
* The term synthetic does not tell anything nowadays. You may have heard that the Castrol Syntec uses a Group III hydrocracked base stock but call it synthetic. The Group III hydrocracked base stock is a super refined crude oil stock, i.e., dino.
* Well, Mobile 1 lost that advertising battle in court against Castrol, so they started the tri-synthetic by mixing some Group III hydrocracked base stock in their "synthetic" oil. If you look at the Mobile 1 spec sheets on their Website, these oils are called hydrocarbons now.
* So now only Amsoil, Quaker State, Pennzoil, and Vavoline, plus a few others are truly "synthetic".
* Give Pennzoil credit as they use "PureBase" base stock in their $0.99 per quart oil (when on sale). These are the same hydrocracked base stock others call "synthetic".
* The recent Ford 5w-20 oil also uses a hydrocracked base stock. I guess at that light viscosity, the regular Group I or II base stock just won't cut it.
* Chevron Delo 400 15W-40 uses a Group II base stock. Mobile Delvac 15W-40 used use a Group II base stock but the "new" recipe mixes some Group I base stock in it to "increase performance". Shell Rotella uses only Group I base stock and that is why it is kind of inferior in many properties such as pour point, flash point, etc.
Old Feb 22, 2004 | 04:08 PM
psychocabbage's Avatar
hmmm.. Many have done Oil analysis on Mobil 1 so I'll keep using it since they took the time and $ to send it out to get it checked..
I tried Amsoil.. You can get it cheaper if you are a "dealer" for them which costs a little to get but gets you a cheaper price on the oil. I didnt see any worthwile gain other than the shipped to your door ease..
I am now using Mobil 1. I only do changes when the car tells me too..
I know people that work at Royal Purple and was going to use them, but decided that it wasnt worth it. .Costs more and no HP benefit.. and I doubt that there will be any real noticeable engine wear difference.
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
