Oil on #1 plug
Old Sep 26, 2003 | 07:34 PM
Drew778/94Z's Avatar
Unhappy Oil on #1 plug
What does this mean?
Is the head leaking?
Could it be from the porting, I for got to put RTV on the head bolts
Andrew
Old Sep 26, 2003 | 08:03 PM
96SFLZ's Avatar
Rings, would be my first guess.
Old Sep 26, 2003 | 08:34 PM
I don't think its the rings, only have 24K miles with good oil pressure?
I just install the head 2 weeks ago, I'm thinking I should of put RTV on the head bolts.
Old Sep 26, 2003 | 08:56 PM
96SFLZ's Avatar
That was just a guess. If you have a gauge, you can always check the compression in that cylinder, just to make sure that isn't the problem. I would probably only do that if you've noticed that you're burning a little oil. If you're not, then that's probably not the problem.
This is just me but I would go ahead and put a new plug in there (it'll take 2 mins and a little driving, so why not) just to make sure that you do or still do have a problem.
Old Sep 26, 2003 | 09:00 PM
I know what you ment and thanks for your imput!!!
I did change all the plugs and ran it for a few minutes pulled it out and it was clean.
I just have to drive around now and do WOT blast to see if it comes back.
Old Sep 27, 2003 | 06:04 AM
Kwiksilverz28's Avatar
Valve guides.....bad cylinder head? I am assuming it is oil on the electrode part, not the outside...as in a leaking valve cover....
Old Sep 27, 2003 | 12:21 PM
Ok, after changing the spark plugs yesterday, I drove the car around and drove again this morning.
Right before I got to my house, did a WOT blast, pulled in the driveway and pulled out the #1 plug, it was clean
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
surreybrad
Apr 22, 2015 06:40 AM
Dark Zeiro
Mar 11, 2015 07:15 AM
captcorvette
Mar 7, 2015 12:37 PM
Sandersen511
Jan 13, 2015 03:49 PM
