Noisy...pulley?
Old Sep 9, 2003 | 09:28 PM
  #16
JustAnotherT/A's Avatar
I was trying to find the problem and its coming from the front bottom left area ( ac compressor clutch, timing chain, etc....) if that helps... im gonna try the double pulley. can this cause slower ets by chance from more pull on the pulleys?
Old Sep 10, 2003 | 09:43 AM
  #17
Jilly's Avatar
Originally posted by locosteelersfan
I HAVE BEEN THROUGH THIS ON MINE
The only way to fix it is to go to the double
row pulley setup that GM swithched to because of
this problem. There is a TSB on it. This is the only
way to fix it that works. If you need more I'll
try to find what I can in my papers.
Its a steady whiny chirping sort of sound that makes
your car sound like a POS especially at idle.
Trust me Soap, belt grease, etc will not work
You have to get the new belts, tensioner, and
pulley. My warranty covered it.
I've got the same problem! It's not too noticeable yet but at least I know what it is now.
Old Sep 10, 2003 | 06:04 PM
  #18
daniel g's Avatar
I just noticed this as well. I don't know if it's always been there and I didn't notice it was there. But I recently installed an ASP pulley and noticed it. I don't know if the ASP was the cause, but I'm fairly certain the ASP is on straight, so it was probably there all along and I just noticed it becuase I was listening out for noises after the pulley install.
Old Sep 12, 2003 | 07:15 PM
  #19
ssdrvr's Avatar
my had the same prob fixed for free warranty had expired got a 99 ss
