No help needed..just questions..
Old Nov 3, 2003 | 01:29 PM
S8ER95Z's Avatar
I think I just spun a bearing in my LT1. After many years in the LT1 Help section..I was amazed at the influx of tire, and rim questions in LS1 tech. . What are the problem areas?? Are there any? Im looking at LS1 power now... and im curious. Thanks!!
Old Nov 3, 2003 | 01:46 PM
95GRNZ's Avatar
Cool
Do you mean just with LS1 engines or LS1 F-bodies in general?
LS1 is pretty much a rock solid engine, except maybe for piston slap and oil consumption, but they don't really have any effect on the longevity.
Earlier models (98's?) had some problems with oil pump, I think.
But that's about it. No opti, no intake manifold leaks etc.
Non-engine related problems are warped OEM rotors and leaking rear pinion seal. Not much else.
TS
Old Nov 3, 2003 | 04:12 PM
S8ER95Z's Avatar
TS
That about answers it..thanks. Ive had everything that could go wrong on the LT1 go wrong. Definately time for a change.
Old Nov 3, 2003 | 08:24 PM
95GRNZ's Avatar
Cool
Sorry to hear that...
I had my LT1 for 2 years and from 74K to 114K and the only major issue was water pump. And the previous owner hadn't done anything big, either. I guess I got lucky.
Good luck with your earch!
TS
Old Nov 3, 2003 | 09:22 PM
psychocabbage's Avatar
Re: No help needed..just questions..
I too spun a bearing on my LT1.. traded it in for an LS1... never looked back!
Old Nov 4, 2003 | 07:16 AM
shawnberry50's Avatar
me too..jsut bought my first ls1 on 10/18/03 .... way better than a lt1. i only wish i did it sooner....
fstarockr
Advanced Tech
May 29, 2014 05:33 PM
touch109
Feb 16, 2011 04:41 PM
nosjunkiez28
Oct 18, 2004 09:10 AM
ninetythreez
Nov 19, 2003 03:05 PM
