need more HP...
need more HP...
i have a 2001 camaro z28 A4. the only thing i have done to it is a magnaflow cat back exhaust, but i want to increase my HP more. i have been told that getting a cam would be a good idea but i have no clue what cam to get. and im also wondering what the best header and ORY would be to get. any help would be appreciated, thanks.
[QUOTE=bcphilly01z28;5170041]i have a 2001 camaro z28 A4. i want to increase my HP more.
It's a sickness.............once you get a little you'll want more & more until you think that you'll never have enough. Weclome to the club........as far as I know a cure for what you have has never been found!
^ What's your ability level? Mechanically inclined?
A cam is a bit of a step for first mods..
Lid + Filter.
P+P'd TB
LT's
Free mods (check my stickey up top.. there's a Free mods section.)
Do some susp mods too to help you get that power you already HAVE to the ground a bit more efficiently. LCA's and SFC's first. .
Where do you want your power? Off the line? Up top and tach the **** out of it? How many miles on it? What do you think you may want to do eventually? Supercharger? Nitrous? N/A? Turbo? Stroker? Stock displacement?
Lid + Filter.
P+P'd TB
LT's
Forget the more power concept. There are mods that will make you faster but will dyno lower. Build your car as a complete package.
Mod your suspension. More power is nothing if you can't put it down.
Put a looser converter on it. This will actually make you dyno lower (less power), but you'll run ~1/2 sec quicker ET's. Couple this with 3.73 gears and a trans cooler and you'll be much faster and yet never added any horse power.
This will also set the stage for when you do add more power.
i have a 2001 camaro z28 A4. the only thing i have done to it is a magnaflow cat back exhaust, but i want to increase my HP more. i have been told that getting a cam would be a good idea but i have no clue what cam to get. and im also wondering what the best header and ORY would be to get. any help would be appreciated, thanks.Lid
Headers/Y-pipe
Free Mods
Gears/Converter
etc.
The Pacesetters are the best for the money IMO -- $389 for coated longtubes.
Need4Camaro
Apr 3, 2010 06:58 PM
