Comp Cam
Old Feb 12, 2008 | 12:19 PM
kyle67camaro's Avatar
Comp Cam
Ok so I am looking at a Comp Cams 25-torquer v3 231/234 .643"/.598" 111 LSA and I have not been looking at these at all but I found a good deal on one so I was wondering if you think I would like it. I want a pretty mean cam and I was really thinking about the Futral F14, so does anyone think this is close to it and if I would like it or do you think I should just keep looking tell I find one of those or something more like it.
Old Feb 12, 2008 | 02:39 PM
Kraest's Avatar
Retired
You aren't going to get the full story about a cam based on the duration/lift alone. The valve events might be completely different on cam X and cam Y with the same duration/lift.
That cam is more like an F-14 highlift than a regular F-14. Don't plan on using milled aftermarket heads on stock pistons if you use that cam. You'll still have to check PtV clearance on unmilled heads if you ever do a head swap.
Mike
Old Feb 13, 2008 | 06:53 AM
teke184's Avatar
will you like it?
NOPE...not at all. especially since i know exactly what kind of driving you plan to do, and how much, and the other upgrades you have to your car.
that's a pretty lame question don't you think?
figure 400rwhp give or take. choppy idle. the need for very good springs. and like mike said...difficulty upgrading heads.
Old Feb 13, 2008 | 08:23 AM
Kraest's Avatar
Retired
Who pissed in your Cheerios today?
Old Feb 13, 2008 | 01:06 PM
teke184's Avatar
special K with strawberries actually
so i was a bit harsh....but it was a pretty open ended question....with no support info.
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
alliance12364
Mar 6, 2015 04:39 PM
