need info w/ engine swap>>>
Old Jan 8, 2009 | 07:08 AM
  #16
Pachy's Avatar
Cool
thx Shon, i'll be in touch for the parts and also do you sell painless wiring kits for ls2,or at least ls1?, i foud the TC at speed inc, they sell a th400 /ls2 kit,but maybe i can go with the spacer(TC alone is $639.00)thanks again for the help and for the enthusiasm...ahh i found a ford 9" rear end, that ill begin to prepare for the camaro, also i want to put a '98-00 SS front end do you know where i can find one that doesn't cost too much? thx.
Old Jan 8, 2009 | 07:21 AM
  #17
Shon Herron's Avatar
I can get painless kits, but lets discuss the use of the car and what you are wanting to accomplish.
Do not scrimp on the TC, this will make or break the results, on the street and track.
To do the front conversion, start looking for the parts on different websites. Lots of cars get hit in the rear or side and the front is just fine...
Old Jan 8, 2009 | 02:13 PM
  #18
Pachy's Avatar
Cool
the car will be street driven but not a daily driver, probably a weekly driver, also i was planning on using the stock corvette computer and hp tuners, if not i can get a ls1camaro computer or the camaro stock lt1 computer,i'm planning on ls2, cam, intake fuel rail, tb, and about 300 hp shot,also headers and cutouts for the track, i'm also planning on using drag radials(315/35/17)or 26x11.5x15 on weld racing wheels or greg welds,it will be lightened but will retain most of it's interior and will have a roll bar and radio.
Old Jan 8, 2009 | 02:25 PM
  #19
If you have ALL of the LS2 stuff it makes it easier, dont forget the gas pedal. B/c they are drive by wire.
Old Jan 10, 2009 | 07:18 AM
  #20
Pachy's Avatar
Yes , i 'm thinking of not using the fbw and use a ls1 cable unit,also i'm looking for painless wiring to connect the ls2 to the car and i was told that i'll need a ls1 computer..
Old Jan 10, 2009 | 07:36 AM
  #21
This is correct, you will need an LS1 computer, and depending on the CPS on the crank it might need something else, i looked into the LS2 with LS1 PCM but after all the stuff I had to change it was not worth it for me and I can not recall what all is needed.
It would be easier to get the fbw set up and use the LS2 stuff.
But if you want a painless kit let me know.
Old Jan 14, 2009 | 12:26 PM
  #22
Pachy's Avatar
But can i use the ls2 computer??, because i also think i have a harness. thanks.
Old Jan 14, 2009 | 12:28 PM
  #23
IF you get the pedal assembly for the drive by wire. the LS2 PCM does not have the ability to control 'things' without the 'dbw' stuff.
Old Jan 18, 2009 | 05:11 AM
  #24
Pachy's Avatar
I think i'll be going with a haltec stand alone computer i found a f 10x, and i'l buy the harness for the fuel injectors..
edman
Jan 25, 2015 02:41 PM
Not Dave
Dec 11, 2014 06:32 PM
bernie1951
Dec 10, 2014 10:03 AM
Nostang 96z
Sep 15, 2002 10:15 PM
