Need help, Tips motor mount install>>
Well I'm stuck. I got the passanger side poly motor mount in, took about 2 hours. Hooker LT slide right in, perfect fit. Drivers side motor mount came out real easy, just like the passanger. This is where the fun starts. I'm by myself, so managing the jack is tricky, but I like about 1/4 inch to get the 18mm bolt back through the hole. I'm using prybars, jacking the motor up, even loosened the passanger side mount. No luck. What else should I try? I have to have my car before I go to work Monday night. HELP
__________________
__________________
Loosen up the motor stands where they bolt to the K-member and the mounts where they bolt to the motor. Put the big bolts thru then tighten the mounts to the motor then let the motor settle and tighten the stand to K-member bolts.
99TransAmWS6
Feb 12, 2015 07:23 PM
