Need help with a couple of ground wires.
Old Feb 14, 2009 | 04:55 PM
johnny6's Avatar
Ok so my engine is all back together again after my h&c swap but i'm trying to turn the engine over for the first time and i'm having issues. First off, ground wires.....I got all of them hooked up (including the ones behind the drivers head) except for the braided one on the drivers side that comes out of the harness bundle of the o2 sensor and also the ground from the battery. Where does the braided one go, chassis or block? And where should i bolt up the ground for the battery, block or motor mount nut? Right now i have the battery ground bolted up on a nut on the suspension and when i try to crank the engine over the starter does not do anything......Also there's a ground on the drivers side o2 sensor harness.....Where does that one go? Sorry for all the questions, i'll take pics if anyone needs to see what i'm talking about.
Old Feb 14, 2009 | 05:27 PM
mook99TA's Avatar
as long as they are grounded you should be fine. Just check to see if the grounds are good.
Old Feb 15, 2009 | 06:44 AM
AL SS590 M6's Avatar
Moderator
I think that the main battery ground needs to be hooked to the motor.
Old Feb 15, 2009 | 08:43 AM
johnny6's Avatar
Finally the weather cleared up, i'm going to go mess with it in a few minutes.....Thanks for the info guys.
Old Feb 15, 2009 | 11:38 AM
johnny6's Avatar
All done! Finally got the car started and man is it loud (open headers) After i fixed those grounds it cranked right over Now i just gotta fix a couple of leaks and i'll be good to go.
Old Feb 15, 2009 | 07:02 PM
Kraest's Avatar
Retired
Take some vids of it
Old Feb 16, 2009 | 09:05 AM
johnny6's Avatar
Will do Right now i'm chasing an oil leak that's coming from the top somewhere and running all the way down to the tranny, knowing my luck it's probably the oil pressure sending unit.
Old Feb 17, 2009 | 06:45 AM
Moderator
Almost has to be.
KYWes
Jun 14, 2022 06:52 AM
pimpen1024
Aug 19, 2015 08:36 PM
RUNMYTA
Jul 15, 2015 07:50 PM
gelbza
Jul 12, 2015 08:10 AM
asilomar244
Jul 12, 2015 05:53 AM
