Need Advice!!
Old May 17, 2005 | 10:43 AM
sunsetorangess's Avatar
Need Advice!!
What would be the best thing to do with cutouts for performance? Put dual cutouts in place of the cats or put a single one?? If just a single, would this give me as much hp as dual cutouts, and where do you mount a single one?? Thanks.
I did a search but couldnt exactly find the answers i was looking for, so i figure i just ask.
Old May 17, 2005 | 11:15 AM
teke184's Avatar
Re: Need Advice!!
is this on the car in the sig??
with the cam, i would do dual cutouts, put them back a little ways from the collectors on the headers so that you don't mess with the A/F.
duals will probably get slightly more than single, but not a ton. probably more peak, but you may lose some in the lower rpm (or just not gain as much)
Old May 17, 2005 | 11:21 AM
Re: Need Advice!!
Yea it's for the car in the sig. So exactly where would you recommend putting them?? In the Ypipe?
Old May 17, 2005 | 01:53 PM
SSpdDmon's Avatar
Re: Need Advice!!
I would think one cutout in the I-pipe before the bend over the axle would do just fine. You don't want it too close to the O2 sensors like previously mentioned. But, I highly doubt you'll see a difference between 1 and 2 cutouts. Just my $.02
Old May 17, 2005 | 05:04 PM
Re: Need Advice!!
well im about to get a tune and i'm going to delete the o2 sensors, would you still recommend in the i?
Jeff1904
Jun 5, 2016 05:00 PM
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
