Need Advice!!
Need Advice!!
What would be the best thing to do with cutouts for performance? Put dual cutouts in place of the cats or put a single one?? If just a single, would this give me as much hp as dual cutouts, and where do you mount a single one?? Thanks.
I did a search but couldnt exactly find the answers i was looking for, so i figure i just ask.
Re: Need Advice!!
is this on the car in the sig??with the cam, i would do dual cutouts, put them back a little ways from the collectors on the headers so that you don't mess with the A/F.
duals will probably get slightly more than single, but not a ton. probably more peak, but you may lose some in the lower rpm (or just not gain as much)
Re: Need Advice!!
Re: Need Advice!!
I would think one cutout in the I-pipe before the bend over the axle would do just fine. You don't want it too close to the O2 sensors like previously mentioned. But, I highly doubt you'll see a difference between 1 and 2 cutouts. Just my $.02
Re: Need Advice!!
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
