my tires...
Old Oct 28, 2003 | 11:51 PM
coogsLS1's Avatar
my tires...
I have BFG G-Force T/A KDWS
are they considered regular street tires? Or are they meant to heat up (like a performance tire)? Just thinking about the water at the strip...
Old Oct 29, 2003 | 12:52 AM
94ZRiCeKiLr's Avatar
just dry spin them a little bit to clean em off, heating em just makes em greasy and slick.....a good rule of thumb is dont burn out long enough to make smoke.
Old Oct 29, 2003 | 07:18 AM
teke184's Avatar
yeah a little sqeal to clean debris off, anything beyond that just reduces the tire life.
you are better off playing with pressure than doing burnouts
Old Oct 31, 2003 | 01:05 AM
coogsLS1's Avatar
what would a good psi be for nice traction?
Old Oct 31, 2003 | 01:13 AM
i wouldnt go lower then like 22.
i run 18... but thats a drag radial....
i DID have a friend with a bolt on LT1 go 1.7X 60 foot on a sumitomo street tire with 12 psi in it, but i WOULD NOT suggest trying it.
Old Oct 31, 2003 | 07:57 AM
Greed4Speed's Avatar
Lower pressure doesn't mean better traction in a radial. If you drop the pressure in them the traction patch cups leaving the outside treads w/all the traction duty. If you over inflate them they arc, and you run on the inside treads. Adjust your pressure so your burnout looks even and this is your optimum tire pressure for a radial. If they are inflated incorrectly, they will not wear evenly.
Lower pressure works on bias ply tires. (MT's) They have a weaker sidewall is why.
Old Oct 31, 2003 | 11:29 AM
whoa guy's Avatar
i ran my old set of KDW's at the track.... 20psi in left rear.... 18 in right rear. best 60' of 1.8
Speed2Much
Track Kill Stories
11
May 1, 2005 09:03 PM
Dan00Hawk
Aug 10, 2004 05:51 PM
Y2K1 SS 5.0 THIS
May 12, 2004 09:22 PM
SPANKY LS1
May 12, 2004 05:28 AM
Punisha69
Jan 29, 2003 07:37 PM
