My LS1 traps 97...help!
Old Jun 9, 2005 | 07:42 PM
  #16
UtOhCop's Avatar
Re: My LS1 traps 97...help!
Originally Posted by Strahley
What gears do you have? What kind of weather were you running in? When you cleaned your MAF, did you make sure not to touch the little sensors?
It wouldn't suprise me to see a '98 convertible automatic car trap less than 100 in bad weather, especially with 2.73s
Asked the same question. Never got a response. My bet is that he has no clue what gears he has. Probably has 2.73's.
Old Jun 9, 2005 | 10:25 PM
  #17
95Z28DROPTOP's Avatar
The car has 3.23's. Also, the MAF was cleaned after the poor numbers at the track. I assure you that I didnt touch any of the little sensors.
Old Jun 10, 2005 | 12:48 AM
  #18
Knowklew's Avatar
Well if you cleaned the MAF AFTER you went to the track why don't you go back to the track with your clean MAF and run again?
Old Jun 10, 2005 | 01:12 AM
  #19
blind527's Avatar
My car traps 100@13.8 *97 A4 LT1* without headers or anything...
Just a CAI, thermostat, PCM tune, LT4 KM. Anyone think that's pretty good for a light modded 97 auto with no traction? My rear tires are completely bald! Hoping some drag radials and a torque converter will bring me at least a 13.2
Something isn't right, LS1's are usually trapping 102-103.
Old Jun 10, 2005 | 06:49 AM
  #20
Lunch Box's Avatar
He said earlier that he was going back to the track on Thursday to test things out again.
Check back on the first page - it's right there.
Old Jun 10, 2005 | 09:29 AM
  #21
UtOhCop's Avatar
3.23's and trapping 97. Yikes. Clogged injector?
Old Jun 10, 2005 | 10:01 AM
  #22
Knowklew's Avatar
So what times did you run with the cleaned MAF?
Old Jun 10, 2005 | 05:17 PM
  #23
It rained yesterday. It will happen next week.
Old Jun 10, 2005 | 05:40 PM
  #24
camzaro28's Avatar
even though this was my lt1.
i put the k&n on and fuel filter after my first few times at the track. best stock was 14.6@95
then after k&n and fuel filter, my nest two times out i ran 14.3@98. spinning, but the traps came up quite a bit.
i am just saying that fuel filter was probably my culprit. u should try that also over the next week
Old Jun 11, 2005 | 08:14 AM
  #25
danziger's Avatar
Yah. Fuel filter is a good start. Have somebody AutoTap the car for you...
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
1slow93z28
Sep 1, 2015 06:22 PM
