my A/C exploded, need advice
Old Mar 13, 2005 | 02:53 PM
anasazi's Avatar
the AIR pipe on the passenger side moved over enough so that it rubbed / burned a hole through the metal A/C line and it is now venting into the atmosphere (yes, as i type this)
what should i do? is there anything i can do?
the part doesn't look terribly hard to replace, just one bolt at either end. is there anything i should know about or worry about while replacing it?
how is moisture going to affect the system? i'm going to get it fixed within a week at the most i hope. i intend to replace the pipe myself and have a professional put freon back into it.
Old Mar 13, 2005 | 09:01 PM
twozs's Avatar
Re: my A/C exploded, need advice
its empty now so replace the line and pull a vaccum on the system to leak chech and evaporate the moisture and fill with freon and oil. most deffenetly find out why this happened and correct the original problem. i would immagine that freon if it were sprayed on a blazing hot exaust manifold will prouduce a gas called phosene(spelling?) which is highly toxic
magman
Apr 15, 2016 03:08 AM
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
