mti R1 cam
Old Jan 15, 2006 | 11:05 AM
TXZ28LS1's Avatar
mti R1 cam
im curious bout this cam. i believe the specs are 232/236. i just wonder why more people arent running this cam. it seems like everybody is running 23xish/23xish size cams but not this one. anybody know how much hp this would put down on an A4 with stock heads and all the bolt ons?
Old Jan 15, 2006 | 01:34 PM
teke184's Avatar
Re: mti R1 cam
stock heads it should put you around 400hp.
it's a similar cam to the torquer i run, and i'm at about that through and m6. so with the slightly higher exhaust duration you may pick up the difference since you have the a4.
Old Jan 15, 2006 | 07:48 PM
TXZ28LS1's Avatar
Re: mti R1 cam
thanks teke..i just wanted to ask, cuz it seems like everybody always recommends going with a cam around the r1 specs but nobody is running it. thanks..if anybody else has any more input it would be appreciated...
Old Jan 16, 2006 | 04:50 PM
Greed4Speed's Avatar
Re: mti R1 cam
Cost and popularity. More people run them in Houston I'd imagine.
Old Jan 16, 2006 | 06:34 PM
SSpdDmon's Avatar
Re: mti R1 cam
http://www.texas-speed.com/shop/item...d=168&catid=44
Old Jan 16, 2006 | 06:42 PM
teke184's Avatar
Re: mti R1 cam
just for reference...i put in the first version of the Torquer cam...
full boltons and dyno tune...382hp
granted the clutch was slipping, but it seemed to happen before the peak in the hp curve.
rideordie
Nov 5, 2019 04:52 PM
NED4SPD
Sep 16, 2002 10:45 PM
Bill'sWS6
Jul 19, 2002 11:21 PM
Bill'sWS6
Jul 19, 2002 01:08 PM
