Ms3
Old Feb 20, 2008 | 08:22 AM
kyle67camaro's Avatar
Ms3
Ok I know that its really hard to tell from such little numbers, but I am hoping that people have just kind of heard story's in the past. I am looking at some speed inc rgr heads and the guy has a futral f13 cam that will work with it, but there is another guy that has a ms3 cam for sale and I know that ms3 has some bigger numbers. I just dont know if I will have to worry about my pistions hitting or if they are ment to be fine or if the f13 is just close enough to not worry about it at all. Well I hope you have some help for me. Thank you so much
Old Feb 20, 2008 | 01:58 PM
Kraest's Avatar
Retired
The MS3 at 237/242 .603/.609 is too big for a stock motor IMO, unless you like having no bottom-end power. It's a mid-high rpm cam made for a 1/4 car with big gears and a big converter. You can expect to not make power until 4000+ rpm if you're using it on stock cubes.
Yes, you'll need to check PtV clearance on that cam with aftermarket heads.
The F-13 would be a much better cam for an NA 346ci street car application IMO.
MysticBowtie
20
Oct 9, 2015 11:19 PM
Collector Car
Feb 16, 2012 08:11 AM
dookie454
Nov 28, 2011 01:18 AM
SNAKE_EATER
Feb 11, 2010 09:07 AM
LT1_King
Jan 4, 2007 11:03 PM
