Motor Oil And Trans Fluid Leaking
Old Nov 2, 2003 | 01:57 PM
carr_z28's Avatar
Hi guys and gals. I was wondering if any of you could help me to figure out why my 98' M6 Z is leaking both motor oil and trans fluid. It is leaking oil out of the back of the engine, I think it is inside the bellhousing, because above it is dry. As far as the trans goes, it looks to be leaking at the front of the trans, behind the bellhousing. My thought is that it is the rear main seal on the motor, and the front seal on the trans. I just wanted to know if anyone had the same problem or any reason on why it started leaking. If anybody thinks it is leaking from somewhere else I am open to suggestions. Thank you very much for all of your help!!!!
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
jb4xx
Feb 2, 2015 10:00 PM
artic94
Jan 17, 2015 11:19 AM
Jan 5, 2015 07:14 PM
