More suspention questions?
Old Jul 24, 2002 | 06:44 PM
Ben_01Z's Avatar
Post More suspention questions?
how do DMS suspention products compare to BMR im already going to get DMS lowering springs but i want to know if DMS makes better LCAs and SFCs too
Old Jul 25, 2002 | 06:26 AM
chuck's Avatar
Post
DMS = Granatelli
Personally, I won't run a poly/poly LCA anymore, but have had the Granatelli LCA's in the past. They are well made. I use and suggest the LG poly/rod end LCA's. Poly will bind, the rod end keeps everything moving freely as it should.
98 Z28 1LE M6 | Autox/RR toy
01 Trans Am M6 | Daily driver, some mods
1LE.net
Old Jul 25, 2002 | 12:31 PM
Eric @ DMS's Avatar
Post
Chuck,
Please enlighten me as to how we are Granatelli? Huge difference there between both companies..sort of like saying Pepsi=Coke
Eric Cuaresma - CamaroZ28.com Sponsor!
President/Co-owner of Dynamic Motorsports, LLC (DMS)
"Leaving the competition behind..."
Website: http://www.dynamicmotorsports.com
Email: eric@dynamicmotorsports.com
- A performance company by performance enthusiasts FOR performance enthusiasts!
WE WORK TOWARDS HELPING YOU, NOT TOWARDS MAKING MONEY!
Old Jul 25, 2002 | 12:56 PM
Ken S's Avatar
Post
If your getting lowering springs, you should probably get a set of matching shocks because the stock shocks would most likely be overwhelmed and not be able to dampen the springs effectively. And you'll probably want LCA brackets to make sure your LCA's stay parallel to the ground.. and you might want to double check your pinion angle..
Old Jul 25, 2002 | 03:42 PM
Eric @ DMS's Avatar
Post
Oops forgot to post my take on ends...
Poly bushings do not bind. I've always had poly bushings on my SS and have done it all (drag racing, canyon carving, autocrossing, etc) and never ran into problems. Naturally anything can fail as will a rod end. Poly
has deflection which makes it very streetable. Its better even then natural
rubber. IMO - having a poly bushing on one side and a rod end on the other
has no purpose. If you don't want deflection then why have poly on only one
side. Does that make it half right or half wrong?
Old Jul 26, 2002 | 02:23 AM
acarnut's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Eric @ DMS:
Poly bushings do not bind. I've always had poly bushings on my SS and have done it all (drag racing, canyon carving, autocrossing, etc) and never ran into problems. Naturally anything can fail as will a rod end. Poly has deflection which makes it very streetable. Its better even then natural rubber. IMO - having a poly bushing on one side and a rod end on the other has no purpose. If you don't want deflection then why have poly on only one
</font>
Nice sales pitch. What you need to do is re-post this to the Auto-X forum. You'll get your answers there.
Old Jul 26, 2002 | 03:22 AM
redz_02's Avatar
Post
Personaly i think poly is good. They are alot stiffer than stock rubber and not as noisy as rod ends. The whole defflection thing is a concept that global west pushes for their spherical rod end's as compared to the poly's. If greased properly, poly should not be heavily affected by deflection. The only mismatch i thought to have a purpose is rubber/poly to soften the ride. Poly/rod end combos defeat the whole of perpose of haveing rod ends by the whole deflection concept. The only part i would seriously consider rod ends is on your a-arm's b/c they will have i considerable amount of movement compared to LCA's on the track. Anyways, If you are getting DMS springs than i would stick with DMS. Usualy suspenion components are engineered to match. They are all good and usualy price is the deciding factor.
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
Borla (the expensive cut-out), Wisperlid W/K&N, FRA, Cags eliminator, Strange 4.10's, G2 Rear Girdle, Valv. Synthetic 10W-30, Redline gear oil, Fat hurst shift ****, Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtrpro 1000, Kicker 12L7 in a milhouse, Focal polykev K2's, Focal utopia 6" audiom midrange.
Old Jul 26, 2002 | 10:24 AM
Eric @ DMS's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by acarnut:
</font>
Sales pitch? For those who know me here and seen my posts..I give my honest opinions as well as my experiences. I've never had any problems with poly bushings...however I do encourage him to ask around so that he can make an informed decision
Old Jul 29, 2002 | 07:19 PM
chuck's Avatar
Post
Chuck,
</font>
I admit that I made an ***umption that you are reselling the GMS suspension parts based on your close physical proximity to Granatelli, the fact that you have offered GP's on Granatelli products that no one else to my knowledge even sells, and the fact that the photos on the respective websites show a very similar product.
http://www.dynamicmotorsports.com/images/DMS_SFC.gif
http://www.granatellimotorsports.com/images/gm204.jpg
Note that they are flipped 180* in the photos. Your prices are MUCH better though, and as I stated, I have owned Granatelli LCA's in the past and they were a well made part.
I am sticking to my story that poly/poly LCA's bind up and need to be disassembled every 3-4 months to be greased. I have never had a set that would properly lube through the zerk. Rod ends are what most serious racers use.
Old Jul 29, 2002 | 10:44 PM
Eric @ DMS's Avatar
Post
I see where you are coming from. Keep in mind that in this industry, you form acquantainces, frienships, and conenctions with other manufacturers, vendors, sponsors etc. I have known JR for a while now and we've been good friends. You're right we're not entirely too far from one another (and equally close to Paxton, MMS, and Vortech among others). But that doesn't mean DMS = Vortech, or DMS = MMS etc.
Obviously many companies sell the same type products as all others (ex - we have our SFCs, Granatelli has their SFCs, SLP has their SFCs, BMR has their SFCs, and the list goes on). There is only so much deviation one can have between products. In many instances, companies have their products made from the same fabricator, however rebadged for thier company. Take LCAs for example, all LCAs look alike. Some are beter quality than others but they still look alike.
I'm not trying to change your mind on the poly/poly issue. Everyone has opinions based on experience. That's where I'm assuming you got yours. I have used poly/poly for years and never had any problems...guess I'm not now or ever was a serious racer then
No worries though..I assure you..I"m not Granatelli..you can ask the many that know me personally
Cheers
Old Jul 30, 2002 | 10:35 AM
Granatelli's Avatar
Thumbs up
Look at all this free exposure - I love it
Manufactures of the only 50 State Legal "Truly Calibrated" Mass Airflow Sensors. Granatelli Motorsports Suspension components are back - Great parts and Great prices
Old Jul 30, 2002 | 03:46 PM
chuck's Avatar
Post
I never meant to imply that DMS and Granatelli were the same company, and should have been more clear.
Also, Eric and/or JR might want to look at this post.
Old Jul 30, 2002 | 04:30 PM
Eric @ DMS's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by chuck:
</font>
All is good buddy . Thanks for the heads up with that link...
Old Jul 31, 2002 | 05:28 PM
acarnut's Avatar
Post
Sales pitch? For those who know me here and seen my posts..I give my honest opinions as well as my experiences. I've never had any problems with poly bushings...</font>
That's the pitch. But as a salesman, I don't expect you to point out the drawbacks of your products. You're here to sell stuff (nothing personal, but it's true).
Poly bushings do not bind...</font>
Of couse they do. That's why LG (and others, like GW) acknowledge this and offer LCAs with rod ends.
Yes, on a lowered car with higher rate springs, shocks, and sway bars there's not much wheel travel, reducing the occurrence of bind, but on an otherwise stock car they can act like a huge rear sway bar.
click here
The bushing stiffness that makes them popular is the same thing that works against you when the arms need to rotate on their mounts - that's why grease does nothing for bind. But greasing them can temporarily reduce squeaking and stiction.
I tend to ignore this in the For sale and GP sections, but this is LS1 Tech.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
